Oil cooler bypass
Oil cooler bypass
86 S/C
I picked up a used radiator that does not have the oil cooler, I heard if you use an external cooler this would work better to keep the temps down on my S/C.
Any suggestions?
Any suggestions?
I would think the temps would be more stable with the radiator oil cooler, and its plug and play. The air cooler needs to be much larger to perform as well, will need new plumbing and a place to mount it.
I spoke to Fabio this A.M. and he told me the radiator is reversible, and he is correct.
I have an other issue that I need to address the aftermarket Temp sensor that is used for my 4-Fans keeps going bad, I assume from the heat. Can I wire in the lower Temp sensor to control this? I now have the ability to mount my extra Temp sensor on the top of the Radiator would this be a better place due to it being a return on the coolant?
Fan temp switch testing
I am testing the Fan turn on switch I have two:
One: 3 Ohms when heated with heat gun goes to 0 Ohms
Two: Inf Ohms when heated with heat gun stays at inf Ohms
One must be bad or maybe both; should I not see Inf ohms until it heats up then 0 Ohms?
Man of many SIGs
Don't you need to be moving for the air cooler to cool the oil ? If you are stuck in traffic how much cooling are you getting with the air cooler ? The water pump and radiator are always cooling.
In 1986 Porsche broke the speed record at the Arizona salt flats with a stock 928 @171 MPH does not get more extreme than that.
http://www.youtube.com/watch?v=fsxQZ_H96aY
Comparing air and water, air has vastly lower heat capacity per gram and per volume (4000) and less than a tenth the conductivity, but also much lower viscosity (about 200 times lower: 17.4 × 10−6 Paˇs for air vs 8.94 × 10−4 Paˇs for water). Continuing the calculation from two paragraphs above, air cooling needs ten times of the surface area, therefore the fins, and air needs 2000 times the flow velocity and thus a recirculating air fan needs ten times the power of a recirculating water pump. Moving heat from the cylinder to a large surface area for air cooling can present problems such as difficulties manufacturing the shapes needed for good heat transfer and the space needed for free flow of a large volume of air. Water boils at about the same temperature desired for engine cooling. This has the advantage that it absorbs a great deal of energy with very little rise in temperature (called heat of vaporization), which is good for keeping things cool, especially for passing one stream of coolant over several hot objects and achieving uniform temperature. In contrast, passing air over several hot objects in series warms the air at each step, so the first may be over-cooled and the last under-cooled.
Check this thread out for further details.
https://rennlist.com/forums/928-foru...g-fan-kit.html
Hope this helps
since your 928 is boosted its a VERY good idea to run an oil cooler....the stock oil cooler fittings already have a thermostat built in, so that will work well with any aftermarket cooler.....
some like the in radiator cooler, since it has the added benefit of helping the oil warm up.....
Here is my thinking....the radiator in most 928's is stressed enough...taking the extra heat from the oil or trans oil out of it will make it work that much better....for example my race 84 only uses the radiator for water.....the auto trans is cooled by a huge 1qt cooler and the oil is not cooled at all.....this is fine for my low HP application..but I would NOT go any higher than say 250 crank HP without an oil cooler...
Good info, remember I have an oil line into my supercharger so I need to see if a kit will work.
I like the two temp switch option with relays, one for my condenser fan and the other for the four rear fans.
https://rennlist.com/forums/928-foru...fan-kit-4.html
Trying to find this locally the search on the parts sites do not come up. Does anyone know the specify model it fits?
Man of many SIGs
Did anyone come up with a applicable model and year so I can get the Temp switch from the local parts house.
I searched Pep Boys, Auto Zone, Etc web sites and nothing returns under the part numbers shown.
I like the oil cooler idea; now where to mount it!
Man of many SIGs
FYI, I just installed a Wahler 75/83 version today (951.606.481.00) and the Middle Pin is not the Ground.
Pins are labeled "+" (ground) "1"(75), then "2"(83) in that order and verified on Jeannie's stove :-)
All of our 78-86 SharkBlade Fan Kits now use this switch instead of a temp probe thanks to Hammer!
Thanks again Hammer!
There are also a few other options with different temp settings.
I was also doing some research on the fan switch and found out there are several different kinds for a 951. What is this "operating temperature" subject all about? Which one should suffice for a normal street car. I don't race or anything. I'm guessing the OEM part for this would be the 951.606.481.00?
Operating temps 75/82C Product Code: 251.959.481.75 251.959.481.75
Operating temps 85/93C Product Code: 251.959.481K 251.959.481K
Operating temps 95/102C Product Code: 951.606.481.00 951.606.481.00
944online.com sells a 75 F and an 85 F fan switch.
Thanks!
Thanks!
http://www.napaonline.com/Search/Res...+50062+2062033
