928 Forum 1978-1995
Sponsored by: 928 Specialists
Short shifter question
Old 02-14-2011, 11:10 AM
puyi
puyi's Avatar
Default Short shifter question
Hi all,
I have few question about that stuff for my track car
1/ I am wondering what is the distance between the 2 scews. I would try to make an adjustable one.
2/ the original one is mounted only on the transaxe. If I look the "Roger" system, It is mounted on the chassis. But IMHO, I Think that there is a reason why the original system is as it is. It may occur that the body and motor-transmission system has vibration/variation again each other. So Original system should be more relevant that after market proposal. Is there really what happens, Or people who are using "roger" system did not experienced such problems.
Thanks in advance for your attention
Best
Puyi
Old 02-14-2011, 11:13 AM
Ducman82
Ducman82's Avatar
i have the Roger Shifter and have had no vibration issues. shifter works very VERY well.
Old 02-14-2011, 12:34 PM
Lizard928
Lizard928's Avatar
I have seen a vibration occur with the use of bronze bushings in the rear with my new shifter design.
Many vehicles have the shifter base bolted to the chassis.
I have also seen one car where the front shift rod caused a bunch of vibration. Re securing it solved the problem.
If this is a track which you say it is, then I would strongly recommend my new shifter design!
Old 02-14-2011, 01:35 PM
James Bailey
James Bailey's Avatar
The very early 928s had the forward shift rod guide sleeve bolted to the chassis.....Porsche quickly changed this and mounted it to the torque tube. They obviously wanted all the linkage to be mounted to the engine t-tube trans....perhaps because that 800 lb lump suspended by only four rubber mounts MOVES around a LOT. It does not move far but needs its own shock absorbers
Old 02-14-2011, 02:14 PM
Lizard928
Lizard928's Avatar
Jim,
I believe that the reason Porsche made the change from the chassis mounted rubber piece to mounting it to the TT was more to do with the removal of the drivetrain.
It is actually very surprising as to how little the engine/tt/transmission move around with new motor, and transmission mounts.
Ducman82
Ducman82's Avatar
i have the bronze bushings, and i did have a buzz for awhile, but it went away.
Old 02-15-2011, 10:35 AM
puyi
puyi's Avatar
And how is that new shifter? where is it available and what is the price?
Puyi
Old 02-15-2011, 10:59 AM
Lizard928
Lizard928's Avatar
Well seeing as how I designed it I am biased!
However, contact ROG100 for current pricing. They are in stock.
Old 02-15-2011, 11:09 AM
SQLGuy
SQLGuy's Avatar
I have bronze bushings, and a rattle from the shifter handle at certain speeds. It sounds like the end of the shifter handle itself actually rattling around inside the ****. It's on my list of things to look into, though I still have to replace the front ball cup anyway. (Will probably do that in the next week, along with swapping the stock O2 for an Innovate wideband.)
Old 02-15-2011, 11:16 AM
ROG100
Basic Sponsor
ROG100's Avatar
We no longer supply the bronze bushes for the "Lizard" shifter but Delrin ones with a round (not elongated) pin hole. No buzzing.
Old 02-15-2011, 05:50 PM
puyi
puyi's Avatar
So I understand that you, Roger are the supplier of the Lizard short shifter?
Puyi
Quick Reply: Short shifter question
