928 Forum 1978-1995
Sponsored by: 928 Specialists
Any experience with "sticking piston rings" on dormant engine?
Old 02-23-2011, 11:46 PM
  #76
WallyP
Rennlist Site Sponsor
WallyP's Avatar
If you plan to install new ones, no real reason to check them for wear. We have had some folks who want to spend as little as possible to get it running again. You need to get the piston grooves clean without scarring or scratching the sides of the lands at all, as those are the sealing surfaces.
Old 02-23-2011, 11:47 PM
  #77
928 at last
928 at last's Avatar
Default I'll Defer
Originally Posted by gbgastowers
Wally, Thanks for your reply. Are you saying check the old rings for wear? I have bought new ones and plan to clean up piston and install the new ones. Why should I check the old ones for wear? Gunar
Wally can give you the specifics, but it isn't the rings you're checking.....it's really the bores. The end gap will tell you what size rings you need to go with.....
Old 02-23-2011, 11:50 PM
  #78
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
I already bought 97mm rings from Pelican. I didn't know I had a selection to choose from. I will try and measure but hopefully the 97mm are what it needs.
Old 02-24-2011, 12:03 AM
  #79
gbgastowers
Old 02-24-2011, 03:35 AM
  #80
Roy928tt
Roy928tt's Avatar
Ah, so it was rings stuck in the piston grooves, that will do it every time.
From what you say, the old rings are not that worn at all.
Cheers Roy
Old 02-24-2011, 02:52 PM
  #81
yardpro
yardpro's Avatar
can he not run a "scatterball" cylinder hone through the cylinder to clean it up...
We used these things on nikasiil coated aluminum cylinders on race bikes (dirt) all the time.. you have to be very careful, and only do one or two passes, but it restores the oil grabbing cross hatch, and created a great ring seal.
Old 02-24-2011, 05:16 PM
  #82
Hilton
Hilton's Avatar
No.. the 928 is Alusil, not Nikasil (pistons in a 928 are coated, not the cylinders as is the case with nikasil).
Honing a 928 engine will result in poor compression, blowby, and a poor engine. There should be no cross-hatch marks at all - it should be smooth.
After correct alusil "honing" (more like buffing with a special paste), the surface exposes the silicone at the microscopic level. GBA's bores look ok at first glance.
Old 02-24-2011, 11:18 PM
  #83
gbgastowers
Cheers Roy
I can't get them out. I am using my other pistons with new rings. I have to at least get the rings out of 1 because 1 of my extra pistons is damaged. Soaking one in ATF at the moment and only have 2 bores to go. Gunar
Old 02-24-2011, 11:25 PM
  #84
928 at last
Default You need
To do a search here on the best penetrating oil.......
ATF by itself isn't going to do it (Most likely).
The idea is to soften and or dissolve the carbon that's gummed things up.
(Stuck the rings in compressed mode)
Old 02-24-2011, 11:49 PM
  #85
namasgt
namasgt's Avatar
Have you looked in to buying some berry man degreaser from Car Quest?
If your rings are stuck due to the carbon turning into sticky stuff, it will dissolve it and you can take your ring out and use the same pistons. I have used it to clean 928 pistons with no problems.
Old 02-25-2011, 01:23 AM
  #86
gbgastowers
I think I can get the rings out of one of the pistons and use it as my final one(#7). It's soaking in a mix of everything tonight. I am about done with the major surgery and I can start closing it up tomorrow. It feels good to take care of this major problem. I have made a really big mess so I'll post some pictures of it.
Old 02-25-2011, 01:30 AM
  #87
Landseer
Landseer's Avatar
Good use of the W-S Journal.
I see you have a nice mat to curl up on by the garage door. BTDT.
Old 02-25-2011, 02:04 AM
  #88
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
The best piston degunker I found is Berryman's Chem Dip. Don't get it on you...
Old 02-25-2011, 02:08 AM
  #89
BC
BC's Avatar
I LOVE that stuff. Cleans pistons just by sitting in it. Cleaning the berryman's off - "One glove, one piston, one glove, one piston" - immediately starts to weaken the latex and nitrile gloves. But it WORKS!
Old 02-25-2011, 02:19 AM
  #90
namasgt
namasgt's Avatar
^^^^ that's what I have suggested, powerful stuff, stinks too so you want to do the cleaning in open air, not inside the garage. I think if he uses it he can just reuse the original pistons and put them in to their original bores, since their worn together.
Quick Reply: Any experience with "sticking piston rings" on dormant engine?
