Runs hot
Your coolant temperature with an accurate IR thermometer.
If its getting warm after idling, then I'd replace the thermostat, its large o-ring, and the rubberized metal seal behind it.
If those don't fix it, water pump is suspect
Has the internal T-stat seal ever been changed?
Has the radiator and fluids ever been flushed?
Coolant Level. Percentage water/coolant. Fans operating? One or both?
Supercharged
GT's do tend to run hot (2nd white line or slightly higher). If it's getting hot at idle, how about when you drive it? If it cools down, it could be a fan issue.
Chronic Tool Dropper
What Andrew said. Are the fans running as it "gets hot" at idle?
I just got the car and this is realy the first time I took it out since the bad whether but when I pulled in the driveway I noticed then shut it down.I will look into it more tomorrow it was just to damn cold out.
Good point, forgot that one.
