Wilwood Calipers/Cayenne 330mm rotor swap
They fill my 18" Turbo Twist II's beautifully and stop them like nobody's biz even with my dual MC's. Coincidental, The 1.62" 4-piston Wilwood caliper is the best match for the early factory 928 MC as well. I have not looked at the 928 brake line, but I'm guessing it is M10 x 1.0?
The red-headed stepchild of the 928......"S"
The spindle caliper ears are axial mount 104mm C2C and the hub heights are 74mm. They are non-ABS hubs and they are the strongest of all the 928 hubs as well. I took apart a later 928 hub with the ABS ring and the interface had some text-book galvanic corrosion. Here's some interesting reading...
https://rennlist.com/forums/928-foru...pgrade-rv.html
Finally got the prototype done...I Got the caliper with pads dead-center on the
32mm thick rotor with the new adapter design stepped in at the caliper interface. I also went further and tapped everything metric as the M10 x 1.5 is stronger than the factory standard bolt that Wilwood calls for at the caliper and this makes install a breeze. These will be half moon shaped and mega strong.
4ea.... M12 x 1.5 x 40 at the spindle ....(use 1/16" thick washers only)
4ea.....M10 x 1.5 x 35 at the caliper ....(use 1/16" thick washers only)
Now just have to make them pretty like the 944 adapters and churn out some centering rings.......
What is the OD of the tone-ring? I'm assuming it is the smaller O.D. 90-count? I'm drawing out the final design and there is plenty of meat there that can accommodate a larger OD hub.
Perfect!
I like this set up more than using the parts from a S4.The abs ring from S4 hubs has different teeth and I think after the mod with S4 parts I have a broken ABS.
So I can use Xschop set on the front and S4 calipers and discs on the rear and all is working?
Thanks JB , that is interesting about the rear shimming. The same goes for the 944. I machined 2.7mm thick shims to put 951 fronts on the 944 rear arm for another hybrider. Their C2C caliper bolts are 94mm.
More good news... I set everything back up and it looks like it will clear a sensor tip that would protrude out of the spindle boss. My 85 spindle has the ABS boss cast into it, but it is not machined for a sensor from factory. If someone can post a pic of the sensor tip in relation to the caliper ear mount holes, I will machine these adapters to fit with maximum material. I'm kinda picky like that
This is a great project, put me on your order list when you ready to sell this upgrade. Thanks for all your superb and precise R&D work !
Can't wait to get it on my cars!
Ed Meier
Ed Meier
