928 Forum 1978-1995
Sponsored by: 928 Specialists
79 door lock issues - update broken key/lock cylinder
Old 01-18-2011, 11:31 AM
Go-carter
Go-carter's Avatar
Originally Posted by jwillman
The white plastic connecting rod is intact The broken part was still attached to the white rod and popped off with so think the rod is still good.
I have been to austin VW a few times and always had good luck (pulling parts off Brians old car).
My passenger door lock does not even turn so may hit you up for rekey guidance when the time comes.
Jim
I have a smiliar problem on the drivers side of mine, some times, when I try to open it, the lock seems to "catch" in something, making it not turn at all. Perhaps a rod is bent or something, making it stuck to the frame of the door?
Old 10-13-2013, 06:44 AM
Abaurre
2nd Gear
Abaurre's Avatar
Default Broken Lock Cylinder Arm
Hello! I found this topic and it is exactly my problem. Passager side works perfectly but driver side wouldn't lock. The key activates the alarm just fine, but didn't move the ****. When I dissasemble it yesterday I found the broken piece attached to the plastic arm.
Can somebody help me find this part? Or will I have to buy an entire lock cylinder for this? If yes, does the cylinder without alarm has the same arm?
Please reply fast! I am way south and parts are really hard to arrive. Thanks!!
Old 10-13-2013, 08:37 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
if you had a spare lock cylinder you could take this one apart and replace the locking collar,
the part is not available separately .
Practice taking the new cylinder apart first so you will know better on your lock.
OR take yours apart first an then transfer the lock cylinder and key sliders to the new lock.
NOTE to prevent more damage make sure the inside door lock **** surround is only tightened hand palm snug.
NOTE if you make this tight then it can bind the **** function, and then it will break the new pars.
also dont over tighten 2 screws that hold the inner **** mounting,
and also snug the **** screw,
use loctite on the **** screw in this case less tight is better
Quick Reply: 79 door lock issues - update broken key/lock cylinder
