928 Forum
Sponsored by: 928 Specialists
Tail light cover removal
Old 12-10-2010, 04:48 PM
Abby Normal
In Your Face, Ace
Abby Normal's Avatar
Default Tail light cover removal
Any tricks to getting these darn things off without cracking the cover? It's as if they were silconed Guess it's just the age of the seals..
Abby Normal is offline
Old 12-10-2010, 07:43 PM
jwillman
jwillman's Avatar
Mine were stuck pretty tight as well. The bumper also seemed stuck to the lense assembly. I used a plastic trim pry bar to free the lense from the plastic bumper and then used a 90 deg pawl inside the screw holes to apply some outward pressure working from hole to hole til it popped loose.
Note to self!! Place a stack of soft material on the ground below the lense just in case it pops loose. Don't want to have it chip or shatter if it were to hit the ground. Don't ask me how I know
jwillman is offline
Old 12-10-2010, 08:14 PM
Dave928S
Dave928S's Avatar
Originally Posted by jwillman View Post
Mine were stuck pretty tight as well. The bumper also seemed stuck to the lense assebmbly. I used a plastic trim pry bar to free the lense from the plastic bumper and then used a 90 deg pawl inside the screww holes to apply some outward pressure working from hole to hole til it popped loose.
Note to self!! Place a stack of soft material on the fround below the lense just in case it pops loose. Don't want to have it chip or shatter if it were to hit the ground. Don't ask me how I know
I'll second all that
Holding your breath and swearing also helps.
Dave928S is offline
Old 12-10-2010, 11:59 PM
Mrmerlin
Petie3rd
This Post Sponsored by:
Dow Corning« & DeoxIT«
Mrmerlin's Avatar
note the lens pulls straight out to the rear of the car not at an angle
Mrmerlin is offline
Old 12-11-2010, 11:17 AM
Abby Normal
In Your Face, Ace
Thanks for the tips guys.
The rear side marker and tail-light on one side will not work. Neither side was working and I replaced fuse 40 & 41 and the right side started working. I worked fuse 40 in and out a few times to ensure good contact but still no luck. I'm trying to remove the cover to change the bulb, but the damn cover is really stuck on there and I'm trying not to crack it..
Quick Reply: Tail light cover removal
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
