Solid lifter setup for the 32V - how much valve lash?
Hi all,
I've noticed a few here have converted their 928's to a solid lifter setup (mechanical). I'm doing the same to a 944S right now which uses a nearly identical cylinder head. Would anyone be willing to share what kind of valve lash they are running on the intake and exhaust lobes?
I'm thinking of shimming to .004" intake and .007" exhaust - but I'm not sure if these numbers are realistic. Any help is appreciated guys! Thanks!
Here's some pics to entertain everyone on the process:
Lifters are 35mm solids off the 034-Motorsports website with .195" shims (which I have to machine down to give the correct "lash" plus machine the skirts to fit the valve stems correctly)
I would ask Mike - but these aren't his lifters, a head he's done work on, his shims or anything else - so he doesn't have much reason to give me a hand. I agree though - he does seem quite knowledgable.
The reason I'm going to solids is A) some of my hydraulics were going bad B) they are filled with metal shavings anyways C) This is just cooler. Maybe I'll put Webers on next!
The hydraulics were more expensive than these cost me, and word is they are being build in China now. These are the exact same lifters you would use in a 928 32V fyi!!
I think its a great idea. I would recommend .009" and .012" especially on turbo. Since this is an experiment, being too big with the valve lash just makes noise. Being too small burns valves.
Rest in Peace
Nah - but most 944 owners that have done any serious mods to their car are Turbo owners (8V head like the early 928's) which is not what I've got. - People with S2's and 968's with mods like this are few and far between. Wheras - I should imagine the 928S4 and GTS guys may have a little more dough to spend - and build crazy stroker supercharged high dollar items where the solid lifters would be justifiable. Quote from lindsey racing for solids is over 1K - no 944 owner will let go of that kind of cash easily.
At the time when I bought these from 034Motorsports it cost me $390 including the shims. Compare that to $540 for the Chinese hydraulics on pelican-parts. If you were to do this for the 32-valve V8 in the 928 it would be $780 for solids from 034 or if you had to replace lifters in your 928 and kept OEM hydraulics it would cost you $1080 for chinese INA lifters. I don't plan on ever revving this 4-pot to 9K!! The valvetrain will be lighter, so it should rev better, and it will change the cam profile a bit perhaps for the better perhaps for the worst. I'm gonna use the factory cams. My main concern is what to adjust the lash to - especially on the exhaust valves.
To the OP - hang in there. The people who're serious about engine building and will be both interested and conversant will show up
I'm a cam maker and think it's cool to hear about someone interested in solids but I'm surprised at your reasons. Alot of 928 guys have been using a VW INA lifter which is lighter and cheap too, something like 15 each? China is a real concern and I thought the INAs weren't made there yet, just Germany or South America. Do you have any information on the China link? That would be bad news, we need to find out.
Speaking of China, that might actually affect your lash! If you use original Porsche valves and have high confidence in the valve job trueness, you might be able to run less lash on the idea that it's less likely to sink into the head. Modern replacement valves ARE made in China and DO suck in material and finish. You might want to run a little more lash to allow for settling.
Of course your cam is not well suited to this and it's a horrible idea anyway but interesting at least The Porsche ramp design is suited for hydraulics and doesn't have what is required for a solid lifter.
