928 Forum 1978-1995
Sponsored by: 928 Specialists
CARLS SOLID ALLOY MOTOR MOUNTS
Old 12-02-2010, 01:34 PM
  #31
9x8
9x8's Avatar
I considered those for my project car, but I'm still in doubt.
Basically, for the reasons that were already stated in this thread - eventually something will break due to excessive vibrations and that's not gonna be pretty.
Old 12-02-2010, 01:45 PM
  #32
mark kibort
mark kibort's Avatar
Again, what is the overall goal. there are so many "solutions" just begging for a problem that doesnt exist.
Old 12-02-2010, 02:08 PM
  #33
GregBBRD
Former Vendor
GregBBRD's Avatar
Received 2,477 Likes on 1,468 Posts
Originally Posted by danglerb
As I read it aluminum motor mounts put chassis stress on the driveline, hp isn't the main factor, its how much twisting and other forces act on the chassis which is being held rigid by the drive line. Potholes, speedbumps, and drive ways being more important than hp or torque.
Just my speculation, but seems like a track car with a full welded cage might have less issues than a street car.
Yes, you've got it....almost.
That cage needs to be extremely well engineered for this application and tie in both the front and rear mounting areas, however. If the cage stops just before the mounting area, the twisting loads will be more concentrated in a smaller area and make the problems worse. Think of "gentle bending" over a large area versus reducing that area and "kinking" things. Most cages will tie into the suspension pick-up points, but will not address the actual engine and transmission mounting areas. Most cages will make the problem worse, therefore.
Old 12-02-2010, 02:13 PM
  #34
GregBBRD
Former Vendor
GregBBRD's Avatar
Snake oil.
Old 12-02-2010, 02:19 PM
  #35
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
People are looking for an engine mount that will not collapse. That's the OP's goal, at least. Yes, I know. The impossible dream.
Old 12-02-2010, 02:21 PM
  #36
EspritS4s
EspritS4s's Avatar
What's the difference between collapsed mounts and solid aluminum mounts other than engine clearance? Is that what the OP is looking for, better engine clearance underneath?
Old 12-02-2010, 02:25 PM
  #37
GregBBRD
Former Vendor
GregBBRD's Avatar
Here's the reality of all this:
There are people out there that will manufacture anything, if they think they can make a buck, from it. They don't care who they steal the idea from, they don't care what it does to your vehicle. You have to be the one to decide if you really need what they make, or not. You have to be smart enough to think the whole situation through and decide what the long term effects will be.
This just happens to be a good example. If there are successful race cars not using solid mounts....you probably don't need them for your street car....
Old 12-02-2010, 02:57 PM
  #38
GregBBRD
Former Vendor
GregBBRD's Avatar
Not sure what the OP is looking for.
The difference is that the collapsed mounts still have rubber and allow things to move/flex/twist. Solid mounts do not. They are metal bolted directly to metal. No flex.
So, yes, Kibort has the right idea. A set of dead, collapsed engine mounts would be better than a solid mount...and lower the center of gravity, some.
Old 12-02-2010, 03:36 PM
  #39
EspritS4s
EspritS4s's Avatar
That's what I meant. You might as well leave in the collapsed mounts.
Old 12-02-2010, 03:46 PM
  #40
928mac
928mac's Avatar
Originally Posted by ROG100
Brad,
We are talking about solid aluminium MM's not solid rubber.
Greg - say it like it really is - I agree.
Roger
And I agree with both of you Roger
I do not know why anyone would use a solid metal mount on either the engine or trans.
If they do, they are looking for trouble down the road.
FWIW.
That cutlass of mine that had the solid plate on the front of the engine (earlier post) the vibration of racing for one season spyder cracked the entire crossmember making the car no longer useable.
Old 12-02-2010, 04:45 PM
  #41
123
123's Avatar
I'd guess that Dave Clem (the chassis builder) tried the stock mounts and determined that they would not hold up to the twisting torque of a 675hp four cylinder engine.
Maybe that's why Carl uses them for his race car? After all, his engine is making hundreds of horsepower more than Anderson's and Fan's.
Old 12-02-2010, 05:40 PM
  #42
jeff spahn
jeff spahn's Avatar
There are people out there that will manufacture anything, if they think they can make a buck, from it. They don't care who they steal the idea from, they don't care what it does to your vehicle. You have to be the one to decide if you really need what they make, or not. The general public is not smart enough to think the whole situation through and decide what the long term effects will be.
There Greg, I fixed it for you.
Old 12-02-2010, 05:48 PM
  #43
GregBBRD
Former Vendor
GregBBRD's Avatar
Not sure it ran long enough to matter....
Old 12-02-2010, 05:50 PM
  #44
GregBBRD
Former Vendor
GregBBRD's Avatar
Much better. Thanks, Jeff.
Old 12-03-2010, 01:06 AM
  #45
RED SHARK 1990
RED SHARK 1990's Avatar
Default MOTOR MOUNTS
Was there someone on the forum wanted polyeurethane motor mount made? would that be better?
Quick Reply: CARLS SOLID ALLOY MOTOR MOUNTS
