Brake Bias Valve Photo
I can confirm that the 33lb valve I have fitted is 928 355 305 02
Possibly the single best change I have ever made to any car
My 81 has 33 bar bias valves from the factory along with 993 calipers I added and it feels much better to use the brakes in than my 89 which still has the 18 bar valve in it.
Even without ABS I can stop my 81 much sooner than my 89 and in a much more controllable fashion to boot.
I have learned that getting too much bias in the rear could cause a bit a drama in the rain (wet) depending on your braking style. Something to think about.
Supercharged
I just added a 55 bar valve to the Coke car, replacing the 33 that was in there. I have run 2 season on the same set of rear pads while going through about 5 sets of fronts. Granted this is track driving which is different than street. I just need to wait for the snow to melt so I can give it a test drive to see if I like the new setup.
This is with a mix of track and road - although the track is solely Nurburgring which is not particularly hard on brakes
The road element does include both the Alps and the Pyrenees, not sure whether that makes a difference
Supercharged
That is weird, as I am now using up fronts and rears at roughly the same rate with a 33 fitted
So I may opt to go back to the 33bar valve. Need to take it out for a spin to see how it "feels". Unfortunately there are still several inches of snow on the ground, so I need to wait no matter.
On my recent trip to the Ring I started with a cold tyre pressure of 28 psi all round
This resulted in a hot tyre pressure of 36 psi, all round, perhaps this is too high but it seems to work for me with AD08R
Rear wheels became as hot to the touch as the fronts, so perhaps this means I have exactly the right brake balance now
It was pretty warm so ambient temps reached a high of 29C late in the day
Is this a 33bar bias valve?
