928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing tooth count 86
Old 10-21-2010, 08:36 AM
Tampa 928s
Tampa 928s's Avatar
Default Timing tooth count 86
86
Looking for the following:
I need count on the number of teeth on an 86 and how many tooth gaps are used for the pickup. I posted before but never had an answer!
Old 10-21-2010, 09:39 AM
Landseer
Landseer's Avatar
So what are you counting ?
Camshaft gear or flywheel sensor teeth?
Old 10-21-2010, 09:48 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
I'm pretty sure its 60-2. I'll verify and let you know
Edit: From 928 Motorsports website "The 85/86 US and 84/86 Euro use a 100 tooth timing gear, and the 87-95 use a 60 tooth gear"
Old 10-21-2010, 09:55 AM
Mike Frye
Craic Head
Mike Frye's Avatar
Originally Posted by Tampa 928s
86
For the gaps, isn't it the pair of gaps that let the computer know where it is on the timing ring? I don't think it would work with any other combo.
Old 10-21-2010, 09:57 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
I believe this is for a project, not a stock car.
Mark, I just checked Mike Simards website www.simardracing.com and he supplies his lightweight aluminum flywheel with a 60-2 timing ring.
Old 10-21-2010, 10:07 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
From a thread in 2006:
Originally Posted by Lizard931
The two sensors on the back, the front one is a TDC sensor for testing equipment, the rear one is a hall sensor which is run off a 100-1 ring, and the 2 teeth one on either side of the missing tooth are just slightly wider than the rest, though I doubt it is enough to make a difference
The only issue you will run into with mounting the 60-2 wheel on the front pully of the 928 is that the pulley on the front of the car doesnt have a locating pin so it can move around if the bolt comes loose.
However you can take the flywheel off with the timing ring on it and the timing ring just pops off and you can then install a custom ring with x # of teeth on it
Old 10-21-2010, 12:43 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Interesting - From WKD 493 .421, the Service Information Technik booklet for the '87:
"Fifty eight teeth and one large tooth gap for the ignition system are machined in the
outside diameter of the flywheel ."
Old 10-21-2010, 01:30 PM
Mike Frye
Craic Head
Mike Frye's Avatar
hmm. Maybe the spacing is such that it's considered a 60 tooth wheel, but the gaps are there so there are technically only 58 actual teeth?
Old 10-21-2010, 01:43 PM
mark kibort
mark kibort's Avatar
count them for 180 degrees and see what comes up, (not on the gap side)
Old 10-21-2010, 02:06 PM
Lizard928
Lizard928's Avatar
As stated previously 100-1.
The 2 slightly wider teeth should not be an issue, but I never did use that ring with an aftermarket system.
Old 10-21-2010, 04:21 PM
Tampa 928s
Tampa 928s's Avatar
Looking to add a mega Squirt and need a timing gear that I can count the teeth.
So I need to know how many teeth and how many teeth are vacant to know TDC. 86-I believe is 100 but do not know the missing tooth count.
Old 10-21-2010, 07:22 PM
Lizard928
Lizard928's Avatar
Stated above 100-1 means 100 teeth with 1 tooth missing.
The S4 is 60-2 so 60 teeth with 2 missing
Quick Reply: Timing tooth count 86
