Radiator labels..
Are the labels on the top of the radiator available separately?
Firing Order Decal is.
High Voltage Decal is. AC Not Available |
Be warned however, the new factory hi-voltage stickers aren't the shiny gold foil version like your car probably had from factory - they're a non-foil yellow (I bought them).
There was an ebay seller selling gold-foil versions of 928 stickers I think? |
Gotcha..thanks guys.
Got the 928int C&R today, changed out the O2 sensor, temp2 sensor...and tomorrow will put in the new rad. Left the cooler fittings on the old one down at the shop..and im wore out for today. |
You can get the gold foil versions - check eBay. That's where I found it when I replaced my radiator (BEHR). The foil is very thin and it's hard to put down without bubbles but it is essentially the same design. Just search for Porsche labels - it came in a pack of other labels that are not model specific. Good luck, Andrew
Search for "Porsche 928 Engine Stickers" and they turn up.
