Polyurethane based trans mount
Where can I get a good used or new 928 trans mount?
Also from the pics in the forums it looks like the 5-speed mount and auto mounts are the same dimensionally? I will be designing a Billet-Polyurethane 928 trans mount also with replaceable Polyurethane. |
I've got some spare used mounts that I can ship to you, PM me an address.
For posterity: Old collapsed mount -112 mm https://webfiles.uci.edu/redwards/pu...20112%20mm.jpg New mount dimensions 117 mm https://webfiles.uci.edu/redwards/pu...20117%20mm.jpg |
Thank you, you read my mind. I found a collapsed (looking) one on ebay and didn't want to get the collapsed dimensions transcribed to the new design. Us 948 hybriders have found that a solid trans mount prevents busted CV joints when installing the GM-V8, but is loud as hell as it transmits noises and vibrations. I'm going to fix that problem on 928s as well without using solid billet for frame flex reasons.....
http://944hybrids.forumotion.com/for...0-15.htm#10035 |
