928 Forum
Sponsored by: 928 Specialists
Valve Timing Question
Old 10-13-2010, 04:23 AM
pjburges
User
pjburges's Avatar
Default Valve Timing Question
Why is it that I see some sources say (for the 32valve) "adjust bank 1-4 to the value of 1.8mm" and "adjust bank 5-8 to the value of 2mm"
Why the difference? Wouldn't we want both banks to have the same valve timing...?!
Also, the 928 has a crank position marker, which the 16 valve 944's do not.
What if I took a cam degree wheel and attached it to the flywheel of the 16V 944 and put a mark on the engine somewhere. Could I use that just like a 928's crank position marker?
Enlighten me! Just curious about this valve timing stuff...
pjburges is offline
Old 10-13-2010, 07:37 AM
Landseer
Landseer's Avatar
Maybe best to start with the second half of this thread.
https://rennlist.com/forums/928-foru...elt-on-s4.html
Landseer is offline
Old 10-13-2010, 09:19 AM
AO
Supercharged
AO's Avatar
Shart answer: Thermal expansion
AO is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
