Chin Spoiler available...
Used chin spoilers in fine condition are pretty hard to find so this is a rare opportunity for the 928 community.
This was carefully removed from a MY 1984 928S.
There has been some repair work done but if installed properly, you will barely notice at a meter or two. Any remaining scratches will just buff right out.
If you act quickly and it's still available, you will even receive the horizontal 'grill' and the mounting hardware for the spoiler at no extra charge.
This will be offered out in auction fashion to the highest bidder.
All proceeds to benefit PUSH SAFE- an organization that promotes safe parking lot wheel stop repositioning as well as snow plowing techniques with your precious Porsche without any modifications whatsoever.
Thanks for the interest.
Photos below:
Photos below:
ouch!
Yeah, all the duct tape was affecting the weight distribution between the front and rear axles so it had to go. Got a new one from 928sRus. A 1.5 hour install with the car on a lift.
Thanks for the comments. I need a good laugh once in awhile too.
Thanks Mike for noticing the deck wood condition. I'll get right on it.
BTW: The 'adjustments' we made on the car helped a bit. I noticed it on the way home. I played a bit more with that Bowden cable and found an easy way to reach it: Pull the MAF, reach under the spider from the rear, hold the conector in right hand and use the handle of a rubber coated tool between the spider legs above it, pry it off (toward the driver's side) and extract it through the back to where it's easy to play with it. I did it 3 times on Sunday with test drives between adjustments. Tightening it 2 turns helped with the shift set-up. It now downshifts more readily with less throttle and less hesitation.
Thanks for all your assistance on my own car and of course for your wonderful hosting of the Sharks at the Beach event on Saturday.
Best,
Allen
Best,
Allen
Team Owner
I`ll take it, just send me a check for 45.00 and the shipping charges,
thanks for the new parts.
BTW I suggest to use Thompsons water seal on the deck one coat is all you need
Craic Head
Allen,
I'm glad your car showed some improvement. There's nothing that helps find the best way to do something better than trying all the bad ways first. Sorry about that.
Just kidding about the deck, I mentioned it because it reminded me that mine needs to be done.
See you at the next one.
