Engine Dies After 15 Seconds
Hot or cold, engine runs smoothly for about 15 seconds then dies. I can keep it running with throttle. On the road, engine RPM varies widely at constant throttle and dies at idle. Help. Problem occurred soon after the following: timing belt/WP replacement, pod removal and refurbishment, throttle arm to throttle came off at throttle when I disconnected the front ball connection. Help!
Originally Posted by LGL
(Post 7957098)
Sounds like a rather nasty vacuume leak to me. I love those wheels in your avatar by the way. What are they? Where did you get them and how much? Sorry for the 100 questions but I do like them. Beautiful car. You are not too far from me. We will have to meet up some day. Also there is a very active group of 928ers in Richmond. Good luck on getting this thing running.
Tries to go to zero then picks back up again. Always begins at 15 seconds after engine start.
Thanks Frank,
The wheels are Victors and were about $300 each. Grant |
I was thinking O2 sensor first because of the timing issue but 15 seconds is too short and don't know if yours has one. Can it be that you misaligned the throttle somehow when disconecting the front ball connection (why was this btw?).
Is your idle switch working ?
Originally Posted by jon928se
(Post 7957216)
(Post 7957216)
Thanks Steve. I did the search before posting and tried the O2 sensor fix that the guy with a similar but 75 second interval till the symptom used w/o success. I'll try some visual inspections this weekend. My tach also quit working after my pod repairs so I'm going to try to learn about how the RPM limiter works. The only good news is that all my trans position lights work again and I now have a PK Tensioner and the new designed water pump installed.
PS:
A quick visual found half the top of the water temp sensor missing that feeds the EZF and LH computers. I'm not sure which is broken because the wire appears to be blue/yellow which is different from my diagram. Does anyone know if that could cause my problem ? |
1 Attachment(s)
I think you are describing the Temp II. It's on the front bridge just to right of oil filler. That sensor does feed temp to the computers, needs to be functional.
