928 Forum
Sponsored by: 928 Specialists
Fixed one problem, found another. First tow home.
Old 10-06-2010, 11:32 PM
Speedtoys
Speedtoys's Avatar
Default Fixed one problem, found another. First tow home.
88 S4.
Ok..misses at high RPM..a kinda..well, it wants to 'go'..but cant.
Ok..fuel filter is at least 12yrs old, with a grand total of 500ish miles in that time..could be starved.
Changed the filter, coffee came out the inlet side, was naaaasty.
Car does run a high rpms a little better now, so far so good.
Then on the drive home up Highway9 from Saratoga, the lower pass side of the radiator end tank comes apart from the core.
Dang.
Will pull it, take to a service..see what can be done.
Speedtoys is online now
Old 10-06-2010, 11:35 PM
Landseer
Landseer's Avatar
Can you explain more? What end tank?
Landseer is offline
Old 10-06-2010, 11:40 PM
Speedtoys
Speedtoys's Avatar
Edited..radiator end tank. Loss O' Coolant time. No overheat, I pull over for odd smells...and A/F is a memorable one.
Old 10-06-2010, 11:45 PM
soupcan
soupcan's Avatar
Step 1 - Basic service
Step 2 - Run the hell out of it
Step 1 and 2 done backwards usually results in
Step 3 - Major service
soupcan is offline
Old 10-07-2010, 12:01 AM
Drewster67
Super User
Drewster67's Avatar
The joys of sorting a car out ...
Good Luck.
Drewster67 is offline
Old 10-07-2010, 12:05 AM
Speedtoys
Speedtoys's Avatar
Good Luck.
Absolutely, I didnt expect it to run a -week-, a week ago. So a blown end tank, I can still take with a smile.
Not sure how I was supposed to foretell this event, however. If I follow a previous post correctly.
I mean, I could just ask the parts counter to build me a new car, that'd certainly get the maintenance all caught up.
Old 10-07-2010, 12:25 AM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Originally Posted by Speedtoys View Post
.... I mean, I could just ask the parts counter to build me a new car, that'd certainly get the maintenance all caught up.
Others have done it................. still doing it..........
S4ordie is offline
Old 10-07-2010, 12:33 AM
928 at last
928 at last's Avatar
Default Livin' the dream......
928 at last is offline
Old 10-07-2010, 12:39 AM
928 at last
Default Seriously
If the tabs aren't done in, it's a fairly straightforward repair job. Having said that, you need to find a shop that has experience with the Aluminium / Plastic end tank set up. Did mine this year...(Roger has the necessary parts) and the shop managed a re&re without any loss of tabs.
All has been well since.
Other bits may need dealing with due to age/heat (Recovery Tank and that stupid valve on the line from the rad to the tank) but......
Old 10-07-2010, 12:40 AM
Speedtoys
Speedtoys's Avatar
+Yeahh Boyyeeeeee (c)Flavor Flav
Old 10-07-2010, 12:41 AM
Speedtoys
Speedtoys's Avatar
Ya, figured it'd be a good time for a cleaning of the core as well..an opportunity has presented itself...
Old 10-07-2010, 12:47 AM
928 at last
Default Mayhaps....
If the cooling system was maintained reasonably, you should be OK, as far as core blockages. (My personal experience, YMMV). Others have done these at home, but unless you've got the appropriate tools and heating stuff, and have a gentle touch, I'd recommend a shop handle it. (I've got the tools and experience, but for stuff like this I like to have someone to blame).
Old 10-07-2010, 12:50 AM
928 at last
Default Should mention
The shop charges (I pulled and reinstalled the rad myself) were really reasonable even by Canadian standards. Was like $120. Well worth it.
Old 10-07-2010, 12:53 AM
Speedtoys
Speedtoys's Avatar
Oh yes, absolutely, I want no part of this repair.
Speedtoys
Speedtoys's Avatar
..and THAT used to be $4.56 US.
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
