Coil cover removal
I did the search and find nothing about how the cover comes off of coil on 1988 S4.
I don't want to break it as I see it has a chip out of it. Thank You Thomas |
Cover comes off of ignition coil?
The wire looks like it goes through the plastic cover I believe.
Thomas |
The plastic cover just pops off. It has a cast-in wedge cut out of it so the terminal lead wires can exit. The covers keep the connections clean.
Ah..thats why I didnt recognize that, the Bosch ones dont have that cover.
1 Attachment(s)
Originally Posted by Speedtoys
(Post 7952190)
That cover is one of the cheaper ignition parts, and definitely not your problem. So, Gustatus, I am thinking your running-rich-and-missing problem still sounds like ignition, what have you NOT replaced in the picture below? Ground straps (#27, 28) in place?? Wire set is new, right? Were the connectors new also, or just new wires on old connectors? Plug #8 was the only one fouled as I recall (from a recent post), have you gone over that wire carefully? Swapped it with another?? You can also check it with a multimeter, it will have some resistance, just make sure the resistance is in the same ballpark as the others. A few thousand ohms is fine (resistance wire), megohms is bad. :cheers: ATTACH]479185[/ATTACH] |
No sir, I do not have a coil condom.
I believe I will get one however, now... |
Thank you!
Thomas |
