Intake manifold gasket replacement inverval - '87 S4
In the absence of any issues, what is the interval that people are following for replacement of the intake maifold gasket?
As well, I would think this would be a good time to replace knock sensors and vacuum lines as well, correct? Thanks, Norton |
Never seen a leaking intake gasket...there is always something else wrong, under the manifold that requires its removal.
Besides your list: Hoses to valve covers Hoses to oil filler neck Hoses to idle stabilizer Throttle switch Idle stabilizer Leaking water cross-over Leaking oil filler neck |
And bad flappy actuators :)
I don't believe I have any issues at this time, but I will note the things mentioned for the next time the intake is off.
Thanks again. |
