Brake question
Brake question
I was replacing the flexible brake hoses with stainless steel ones. When I was removing the old flex line from the hard line, the hard line twisted about a 1/4 turn. Do you think this will be ok or should I replace the hard line?
Thanks for any help
Thanks for any help
That depends on the length of tube that was twisted. A wrinkly 1/4"? Get a new hardline. 10" with a 1/4 turn in it? You'll be fine.
What I'd look for is any distortion in the tube wall.
You can get new tube bent at a brake shop. The trick would be the fittings. In my observation (not measured) some of the hard line fittings are standard English sizes (E.g., 3/8") and some are metric. Worth a look-see if the part is hard to get or Porsche-priced. And don't forget the magic words "It's off an Audi 5000."
http://www.cunifer.com/?page=home
Pipe size is 3/16" Never have figured out why even now Brake piipe only seems to be made in imperial sizes.
Just to muddy things a bit. I was told that SS lines are not recommended for street use. The line of course has a rubber inner and the mesh will abraid it and wear out faster that a quality rubber line. If you are tracking it, that is another matter. YMMV.
Been selling Twinkies on Ebay,
have some extra cash right now.
Susan Thomas once told me that the reason not to use the braided lines was that they are teflon, and that teflon isn't elastic. So once it stretches, it stays stretched, and is weaker as a result.
I did the same thing but twisted worst. I cut off the twisted head and put new fitting on. double flare the brake line. It was a streach but it worked.
The old line was rust frozen to the fitting. What you need to do it to remove the caliper from the car, remove the rubber brake line to the caliper by letting the caliper turn and the steel line fixed. Remove the rubber line by fixing the steel head and let the rubber brake line turn.
