Check these: Grey rear blinkers
I think I might have found the source.... waddya say?
http://www.bks-tuning.com/Black/red-...sche-928-GTS-1
painted..if the sun hits them the right way you can tell they are painted but most wouldn't notice. blitz928
Cottage Industry Sponsor
One issue you will encounter with this mod is that your back-up lights become totally useless. Even with my relatively light tinting, the effect is significant.
Reanimator
Re: back up lights; You can buy higher wattage bulbs to fit the socket, and as long as you don't leave them on very long, won't risk melting the socket or lens. 20, 30, even 50 watt bulbs are available to fit the socket, if you have to go that far. I had them (50's) on my Bronco for backing up a dark 100' driveway. NICE near-headlight like illumination in the back with white lenses, so even with red you should still have good lighting. You might have to up the amperage on your fuses, though.
Chronic Tool Dropper
Nicole--
This sounds like something that might be added to a plate frame, so no irreversible damage is done to the car.
I Photoshopped the effect and removed all yellow from the blinkers. I think the grey blinkers look absolutely amazing, especially on a grey 928, and they completely change the rear for better.
Actually the car looks 10 years newer with them.
Before:
Photoshopped (after):
Before:
I tend to try not to give an officer an excuse to pull me over in the unlikely event that I had two glasses of wine with dinner.....or the friendly bartenderess overpoured. Then they find the loaded .500 S+W, two pounds of coke and the headless dead body in the boot..... or something like that
But if the blinker glass was actually grey and you used orange bulbs, then wouldn't it be 100% legal...? I mean that's how many cars' blinkers are OEM, at least here in Europe.
Doing track tech inspection at a POC event a couple Boxsters had blacked out the brake lights one with spray tint the other with translucent film. I suggested that they remove the section at least over the brake lights......before they ran
