Trans fill by cranking
Can I fill my ATF by cranking engine and not starting? I put in 3 qts to start with now it is at the max line. Radiator is out so I did a trans and torque drain. I also changed steering res. hoses. I just can't stay away from it.
Thomas
Thomas
Team Owner
if you turn the trans you will pump fluid through the lines,
either connect them or wait till you have a complete system.
