928 Forum 1978-1995
Sponsored by: 928 Specialists
Building my Radiator
Old 09-18-2010, 08:16 PM
axis of evil
axis of evil's Avatar
Originally Posted by Tails
Thermal Conductivity - k - W/m.K of our radiator cores.
At 125 degrees C the thermal condictivity of materials for our radiators in question are:
Aluminium = 255
Brass = 109
Copper = 400
Conductive Heat Transfer
Heat transfer takes place as conduction if there is a temperature gradient in a solid or fluid
Conduction will take place if there exist a temperature gradient in a solid (or stationary fluid) medium.
Energy is transferred from more energetic to less energetic molecules when neighboring molecules collide. Conductive heat flow occur in direction of the decreasing temperature since higher temperature are associated with higher molecular energy.
Fourier's Law express conductive heat transfer as:
q = k A dT / s (1)
where
A = heat transfer area (m2, ft2)
k = thermal conductivity of the material (W/m.K or W/m oC, Btu/(hr oF ft2/ft))
dT = temperature difference across the material (K or oC, oF)
s = material thickness (m, ft)
From the above it can be seen that aluminum if a better heat transfer medium than brass, however, copper is the best.
I have an aluminium cored radiator fitted, but I have two spare brass or bronze units and I note that the brass/bronze radiators are nearly twice the thickness of the aluminium unit with more finned tubes fitted. I would suggest this is because of the thermal condictivity differential of the core materials to achieve the same cooling capacity.
Some may find this interesting.
Tails 1990 928S4 Auto
I did,Thanks
Old 09-19-2010, 02:05 PM
G Man
G Man's Avatar
I used to work in a Radiator shop years ago. The fin portion of the radiator is made of copper. Tubes are brass. You can get the cores buit to custom specs if you wish. They can buld a core with a more dense fin count for a higher heat transfer area and you can get different sizes of tubes as well. It is possible to get a core with only one row of tubes to as high as six or eight rows of tubes. The end tanks are generally brass with brass fittings soldered to them.
http://www.youtube.com/watch?v=ayQWX...eature=related
Old 09-19-2010, 03:45 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Generally speaking, cooling performance increases with more rows until you get to three or four, then performance actually starts to fall off.
The fifth row becomes a non-cooling bypass, as the air that it sees is already heated by the first four rows...
Old 09-24-2010, 08:34 PM
supercedar
supercedar's Avatar
My radiator is on its way to me. We ended up with 3 rows of tubes 5/8" and they are dimpled for premium cooling, 2 1/4" core, brass tanks and a steel frame. They also used my oil coolers. I'm sure it will be heavy so I will lose a few lbs to make up for it. He under estimated the price so I gave him $600.00 instead of the $550.00 quoted. He assures me it will be a cooling machine and it will not look as good as the aluminum. The other plus will be IT CAN BE REPAIRED IF NEEDED.
Thomas
Old 09-24-2010, 09:21 PM
atb
atb's Avatar
I'm seem to recall that Mark A. had a used copper rad sitting on the shelf many Sharktoberfests ago. Is it still there gathering dust? Might be interesting to see how it was designed.
Old 09-24-2010, 09:30 PM
G Man
G Man's Avatar
So....would there be much of a market for a copper/brass replacement radiator for the 928? I am still in contact with the shop I used to work at. I could chat with the owner about producing these if there was enough interest. Sounds like Thomas got what he wanted with his.
Old 09-24-2010, 09:49 PM
G Man
G Man's Avatar
Thomas. How did they install your oil coolers? On a copper/brass radiator the coolers are usually soldered into the end tanks vs. using rubber washers with nuts on the plastic tank.
Old 09-24-2010, 10:51 PM
supercedar
supercedar's Avatar
He did show me the coolers this morning and explained that they were going to solder them into the brass tanks which were very heavy guage. The rubber washers I saw I believe went to the old aluminum radiator. I will check on Monday to see for sure how he did it. I just put it back in and it fit like a glove. I have to go to the game. I will finish it later tonight.
Thomas
Old 09-24-2010, 10:53 PM
supercedar
supercedar's Avatar
I just noticed you are from Carson City. My cousin owns Adele'S
Old 09-25-2010, 01:31 PM
G Man
G Man's Avatar
Yeah, I'm in Carson. I've driven by Adele's countless but have never stopped by.
Old 09-25-2010, 11:57 PM
supercedar
supercedar's Avatar
So I have installed the radiator and test driven for 50 miles. My guage never got close to to the last white mark. It stayed between the white lines except when getting on it, then it would drop. With the aluminum radiator the guage would ride up close to the final white mark.
I actually like the all black front now. Trans and engine oil are going to run cooler also.
Thomas
Quick Reply: Building my Radiator
