Back from the dyno - VIDEO ADDED
#32
Craic Head
Does anyone else think it's weird that the video shows the front straps holding the car through the wheels?
Isn't that going to do bad things to your suspension?
#33
Nice and easy! At least you make it sound easy. I like the plan to keep it reliable.
High performance and long term reliability is the best benefit Porsche can provide. Good mod the SC. It takes her to another level. Thanks posting some numbers.
As always, now that its sorted what (other car) to do.
Regards,
Regards,
#35
Administrator - "Tyson"
If you didn't use the wheels you would most likely tie the car down with the lower control arms anyway. On an S this could put pressure on the lower spoiler.
#36
Not too much force going backwards, just holds it from bouncing back when it shifts gears. Tow trucks do the same thing.
The switch just ties into the WOT wire going to the LH and the other side of the switch goes to ground. Under vacuum the switch is open, at 0 vacuum it closes and puts the LH into open loop.
One of these switches will work, I just need to contact them to make sure I get the right spec. The have a high/low vacuum port, I guess you can just cap the low port and T a vacuum line to the high port.
http://www.newark.com/jsp/search/pro...-OP&CMP=AFC-OP
#37
Inventor
With a vacuum switch, you'll need a cutout for when the engine is cranking, or the LH may go into flood clear mode.
Check with Alan or someone more knowledgeable, but I think the simplest way to do this, without using a relay, may be to connect the ground of your vacuum switch to the (purple?) starter wire through a large resistor.
A fancier way would be to use the MAP sensor in the EZF. There is a 0-5v output from it on (the empty) pin 21. Use a voltage switch to trigger the WOT.
(Jaycar Voltage Switch)
I'd like to have the frequency switch from there for a road speed trigger.
#38
The one I was looking at was adjustable for pressure (should have mentioned that!), so if it was set to close at say 1 psi it wouldn't go to WOT while cranking.
#39
Inventor
Oops, I didn't read your post carefully (still nursing my first coffee).
#40
Craic Head
We now return you to your regularly scheduled thread.
#41
Inventor
Are you logging the WBO2, or just looking at a gauge when you see the 12's? The 'acceleration pump' shot will look like it's getting rich, but it doesn't last for very long.
The AFR curve looks like a typical S3 at WOT with the stock chipset. Close to 14's at 2500 getting richer as rpms go up. Might be able to make it perkier off the line by richening up the WOT map at low rpms until the boost kicks in. Max N/A torque is at 2700.
If dyno guy was in closed loop at the beginning, it would have likely been in the 15-16's (or worse) to start?
#42
the numbers are good, the curves are not that good. flat torque is not what you want. you want flat HP.
that curve is exactly the same as the peaky HP of a GT3cup car. (flat torque curve)
I have almost the exact same HP with a flat HP curve. the effect is a lot more torque down low and more ave HP. is there a way to increase the boost in the lower range and taper it off toward the top?
Mk
Mk
#43
My old FMU, a standard Vortech unit, didn't add any fuel until about 2 psi and it was crazy lean at tip in, 15-16 just like you were saying.
Welcome to the world of a centrifugal supercharger! They build boost with RPM unlike a roots or twin screw that give it to you right away.
#44
Supercharged
Wouldn't we all...
Mine is adjsutable just the ine Ted is talking about.
Basically you use this pressure switch to tell the LH that you are in WOT mode. Don't touch the EZK. Then when you hit any amount of boost it switches to the WOT map and... BAMN! you're at 12.0 AFR. No tip in.
There's a particular name for these switches, but I forget. Toumov mentioned it in a recent (1 month) thread.
