928 Forum
Sponsored by: 928 Specialists
Premature Timing Belt Failure - Solved
Old 09-01-2010, 11:52 PM
  #31
Ethre
User
Ethre's Avatar
I'm paying a pro-wrench to replace/tension the belt. Its the side effect of having the belt slip and engine die on me driving down the road. I had to get it off the road, and was worried there could have been larger damage (interference issue, which I very thankfully found later seems to be alright on US spec 16v motors)
I don't plan on messing with the tension/changing parts unless I can verify that something needs replacing. I've got plenty of time to look over things and take it slow.
Ethre is offline
Old 09-01-2010, 11:53 PM
  #32
Landseer
Landseer's Avatar
Wrong. Pro wrench must take inventory on every piece in the system. Or he's not.
Landseer is offline
Old 09-02-2010, 12:15 AM
  #33
Ethre
User
Ethre's Avatar
Well, I didn't mean to drag this into a discussion of mechanics. Suffice to say, I appreciate him doing exactly what I asked him to do (diagnose engine issue = turned out to be timing belt, repair = replace belt). I believe he should let me know if he notices anything, but on the other hand I didn't ask him for a detailed examination of the belt system. I think he's more worried about valve-damage (understandable, as I think he works on very few 928s). Of course I would have preferred a 928 knowledgeable mechanic, but you're right on towing adding up, and the closest I'd seen mention of was Atlanta. So, for better or worse, I took the closest Porsche mechanic with a fair reputation.
MrMerlin: I assume from the belt and oil pump gear that all the gears had been replaced with round-tooth versions? I can see the wear beginning on those teeth. Was it noticeable to hand, or just visible at that point?
Ethre is offline
Old 09-02-2010, 12:21 AM
  #34
Landseer
Landseer's Avatar
Understood.
Its kind of a tough spot to be in. I get myself there all the time.
The problem is the scope of work on a 928 timing belt always includes complete review of every part, if done professionally.
This is coming from a guy who has taken the 85 car crank pulley off 4 times this year (so far) because I tried to go economy.
Landseer is offline
Old 09-02-2010, 12:23 AM
  #35
blown 87
Rest in Peace
blown 87's Avatar
For better or worse, you need to trust the guy that is doing the work, if you feel a need to look at his work, you need to do so while he has it apart.
blown 87 is offline
Old 09-02-2010, 12:27 AM
  #36
blown 87
Rest in Peace
blown 87's Avatar
Beginning?
those were wore out many, many miles ago.
blown 87 is offline
Old 09-02-2010, 12:31 AM
  #37
Ethre
User
Ethre's Avatar
I trust him to do the work well.
However, having not asked him to do anything beyond that, I make no assumptions about him finding anything else. I'm absolutely certain he will let me know if he sees issues, but I wouldn't expect him to go looking for additional problems beyond the tensioner/timing.
Even so, I do like to take a look at things myself. Tinker may not have been the right word.
Ouch Landseer - 4 times? I take it you are now very good at pulling it.
Ethre is offline
Old 09-02-2010, 12:34 AM
  #38
Landseer
Landseer's Avatar
Yeah, unfortunately. And that's just that one.
The point is you've set-up a no-win on the car.
Can't just slap on a belt.
Gotta do it all.
Your only saving grace is its non-interference.
Landseer is offline
Old 09-02-2010, 12:35 AM
  #39
Ethre
User
Ethre's Avatar
I can see the curve on the left-hand side teeth, but on the middle teeth it looks as if the coating is just beginning to come off. Or is the coating really that thick (that the middle ribs could be worn to half thickness)?
But I could slap on a belt to get it out of the shop and back in my hands, correct? Kind of like a band-aid until diagnosis and cure.
Obviously it would be nice not to have to touch things after it returns from the shop, but then I run into more time and labor.
Ethre is offline
Old 09-02-2010, 12:37 AM
  #40
blown 87
Rest in Peace
blown 87's Avatar
That coating is about .002 thick.
Those are about as worn as they come man.
blown 87 is offline
Old 09-02-2010, 12:43 AM
  #41
Landseer
Landseer's Avatar
If the receipt doesn't show a new Porsche-supplied pump was used, I'd be changing that too, based on what has emerged about the water pump rebuild process issues. And not many mechanics even know about that. Porsche dealers don't because they use new parts. Most independents are unaware.
Not trying to bust your chops, man, but this is one job that needs the preflight check made by a pilot with a clipboard and pencil, item by item.
Landseer is offline
Old 09-02-2010, 12:51 AM
  #42
Ethre
User
Ethre's Avatar
Thanks Blown. Obviously my eyes need a little adjusting to dealing with these parts.
Not to worry Landseer - I've known that for a while. I realized I was jumping in the deep end when I bought it.
Ethre is offline
Old 09-02-2010, 04:09 AM
  #43
danglerb
Super User
danglerb's Avatar
Professional we could argue about, but NOBODY experienced with a 928 would replace a timing belt without checking the associated parts, which are the portion of the system that typically fails, not the belt itself.
Any shiny spot on the face of the gear tooth that touches the belt and the gear is worn out. There is no acceptable margin of wear for the bare aluminum, its just too soft, and the requirements too critical.
danglerb is offline
Old 09-02-2010, 08:08 AM
  #44
Landseer
Landseer's Avatar
You could get it back into your own hands that way, yes. So long as the timing gears and belt profile match I think. Or pay $3/mile for towing.
Landseer is offline
Old 09-02-2010, 08:41 AM
  #45
WallyP
Rennlist Site Sponsor
I would not replace a working water pump on a non-interference engine.
WallyP is offline
Quick Reply: Premature Timing Belt Failure - Solved
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
