the fun is allready over,,grinding noise :(
Listen to what Greg Brown has to say. Even if your block was contacted by the water pump all is not lost.
You'll know when you open it up and see or don't see score marks where the impeller contacted the block. If they are there, get the tool from this group and repair your block. It used to be if this happened your block was junk. Now it is an "opportunity" to get to know your car even more intimately. Look at the detailed write ups on water pump replacement. You'll get through it no problem.
i ordered the flywheel lock tool , the timingbelt tool, all the rollers, the lasso pump ,,in fact ,the whole kit.
the sound it makes is not so bad , it sounds like a bad rollerbearing. i think if the propeller hits the block ,,the sound would be louder and different.more scraping like.
i drove 25 km with the sound, i think everyboduy would have driven this car with the sound i hear.
how can this happen that the propeller hits the block, first i was thinkng it was the airpump, so i drove home.
at home i listned wit a stick and also a tube,and it came from the wp or somewhere around for sure. difficult to locate, but it sure isnt the other belt driven accesoires.
than,
something strange with the numbers, it seems its not a us-car , but it was imported from the states ten years ago?????
i ordered and send the shop my vin and engine numbers,
and the engine numbers ,,i dont know all details about vins and matching numbers, but something isnt right i think.he shop mailed me its not a us car.
this is my vin and engine number
wpozzzs2zes862597
engine
m28/20
s1eo7122
if it was a row the engine should be a m28/22 ?
strange,,,
than,
wpozzzs2zes862597
engine
m28/20
s1eo7122
strange,,,
Does it have a VIN in the windshield?
Can you show a good engine picture, showing distributor?
The waterpump contact may not make appreciable noise due to lubrication with water as the impellor does its machining of the aluminum. Hopefully it will be ok. The advice to not run it was not given lightly by chicken-little.
It is definitely a US car. The last 6 digits confirm that (86xxxx is US VIN range).
The VIN stampings on US cars are all "zzz" except for the correct one on the edge of the windscreen, and the VIN plate.
Your cars VIN number is: WP0JB0929ES862597
Year 1984
Type 928
CountryCode C02 (US except California)
Engine M28.20
Gearbox A28.01
Options list:
158 Radio "Monterey" - 86 "Reno" - 87
185 Automatic 2 point rear seat belts
190 Increased side door strength
218 License brakets front and rear
418 Protective side mouldings
438 Comfort seat right
464 Without compressor and tire pressure gauge
484 Symbols for controls
490 Hi-Fi sound system
494 2 speakers on back shelf
494 Amplifier system
498 Without rear model designation
533 Alarm system
576 Without rear fog light
650 Sunroof
912 Vehicle without identification plate
Year 1984
Type 928
Engine M28.20
Gearbox A28.01
Options list:
533 Alarm system
650 Sunroof
than,
wpozzzs2zes862597
engine
m28/20
s1eo7122
strange,,,
wpozzzs2zes862597
engine
m28/20
s1eo7122
strange,,,
That is very interesting....a German made car made for the U.S. reimported back to Europe. In this case, ignore everything I said about it being an interference engine.
Done With Sidepatch
Bart - One other thing just for fun, you can look down the top holes of your timing belt covers and watch how your timing belt tracks as your engine is running. When my pump was making that noise, when it rattled, I could see the belt go a little off center. But since your parts are on the way, you could just take the passenger side cover off and watch it.
So with your car being shipped back and forth, back and forth shouldn't you get some sort of carbon credit for the distance covered with no emissions (from YOUR car) Like a PZEV almost! Think of all the KMs traveled with the engine off. You'd have saved way more fuel than those silly cars that shut off at stoplights!
strange, someone at 928 specialists, told me "this(bold)" in an email, so i was thinking i have an european car
Actually, the VIN is a European VIN (ZZZ in the middle instead of 92?. There were basically two designations - Rest of world or US versions.
there are a lot us cars imported , the most i have seen for sale overhere are us cars, they come back because once 25 years old all taxes drop to almost zero. that is why i bought a 84.
taxes for a 92 are 2000 euro and more,,,every year.
i have seen dwayne's topic about the waterpumpdamage. that scares me of, really.... i hope my pump didnt dammaged the block.
There is only one single 928 in the world with the VIN ending in "ES862597" - that's how I looked up your complete VIN, I just ran a database query on VIN's ending in that.
US models have the "ZZZ" VIN on the various parts except the official tags.
The last 6 digits also identify yours as a US model - the range "86xxxx" is for North America. Rest of World would be "84xxxx" in '86.
See this page for more on VIN's: https://rennlist.com/forums/928-foru...in-thread.html
hey , thanks for the vin check,
i have removed the pasenger side tb cover, belt seems ok, does not walk. does not look verry old
the tensioner roller spins free, but does not spin when the engine runs.
it does not touch the belt. dont know if it should touch. maby the belt is to hard tensioned. camgears show some wear at the top of the teeth.
the sound can be the pump or some roller, i cant locate that sound for sure. it deffenitly needs attention.with a stick on my ear it sounds like a ballbearing that missing some ***** and turns with cracking grinding sound, the sound travels trough the waterhose.(the metal corner on top of the engine.)
my parts are shipped, maby they arrive before next weekend.
i have two options,
first,
repair the car on my driveway where it is now in open air. it stands on gravel . the driveway goes slightly up hill.
second
drive it to my wintergarage 4 miles away and do the repair. towing is not possible into that underground garage.dont drive it seems the safest.
on the other hand,,,i drove it 30 miles with that sound. i noticed the sound and drove home to investigate,,i hope its not a dammaged block,
the temp was like normal , in the midle.
i think ill go for the first ,repair it where it is right now, i think its way more simple on my 84 than on the S4. i think if i can lift only the front of the car i can get everywhere.
i am scared to drive it, i wish i could remove the whole tb cover and feel those rolers. i wish i could start right now.
my riviera has realy bad water pump house dammage,realy bad scores in there , i didnt replace that , i just replaced the pump long time ago when it made bad sound (it was not that pump that damaged the block) ,the engine does not overheat with the damage.
is the 928 realy running hot if some scores are in the pump house?
i have two options,
first,
second
Been selling Twinkies on Ebay,
have some extra cash right now.
Bart, someone already said it, but to put it more graphically, you have been kissing and maybe feeling a little bit with your car, now you are going to get to have some down and dirty sex with it. Maybe it is too bad that your relationship has advanced so quickly.
Jerry Feather
Jerry Feather
The repairs are more like making the bed afterward, with a big smile on your face.
at last,i have all the parts, the car is allready jacked up, ready to start on the tb tomorrow in the morning. the parts where kept in foreign customs for more than 12 days
i hope i dont find something bad under the covers,,i didnt started on the job yet ,,i wanted to have all the parts first.
the new laso pump looks great, i hope i dont have any block damage. otherwise ,,,,
the sad thing, i have to repair the car outside because i dont want to drive it to my workspace ,,,an it will be a rainy day tomorrow i hope i have some dry hours),,also saturday will be rainy.
i also have the replacement ac headunit , and allready replaced the shutoff valve. the old valve was not closing , i know that for sure now. the vacuum check valve was also broken, had to suck realy hard to get air trough it.
with some luck i have a car with everything working this weekend.
never did a timingbelt job before on any car, but i think with all the help and links, it will be an easy thing to do.
i will go slow on this. and a 84 looks way more easy.
Team Owner
hey Bart go to the top of the page click on user CP
then click on edit signature,
please add your car model,
and year and,
color and ,
trans type and ,
any options you have,
it makes diagnosis easier thanks, good luck with repairs
and year and,
color and ,
trans type and ,
What do you mean the fun it over?
The fun has just begun!
Following is a step by step picture procedure for an 87... there is a lot in common.
http://dwaynesgarage.norcal928.org/1...0Procedure.htm
Half way through Dwayne's procedure (actually turned the corner and on my way back out...)
Great stuff!
