928 Forum 1978-1995
Sponsored by: 928 Specialists
Track Day.... driveshaft slip out?
Old 08-04-2010, 03:14 PM
RPetty
RPetty's Avatar
I really appreciate all the help and comments to ALL!!!!
Please keep it coming.
Now I have a sense of direction.
Thanks!
Old 08-04-2010, 04:11 PM
IcemanG17
IcemanG17's Avatar
since you 928 ran fine until the clutch was worked on my thoughts are
1: loose front clamp
2: broken input shaft
3: broken TT
none of which are easy fixes...unless the clamp didn't damage the splines.....a loose rear clamp is also possible, but you didn't touch it....so its less likely....
Since your engine isn't a torque monster I think a broken tranny or TT is unlikely..but it does happen...
Old 08-04-2010, 04:50 PM
mark kibort
mark kibort's Avatar
spin the engine, see if the torque tube rotates through the peak holes. common,we are waiting!!!!!
It will and its the 5th gear, I betcha!
Brian. a beer says its the 5th gear input shaft!
Old 08-04-2010, 08:45 PM
RPetty
RPetty's Avatar
Unhappy
Ok!
Let me get the car back home, figure out how to get up my driveway on my lift.
Hey, if it's 5th gear, and I don't use 5th...
Still fix the gear?
I do know we tried to start it in gear... Nothing.
Old 08-04-2010, 09:14 PM
James Bailey
James Bailey's Avatar
Although called 5 th gear it is really the input shaft but is hardened steel and somewhat brittle. The drive shaft fits inside and has MATCHING SPLINES the input shaft has tree slots dividing it into three ears. That allows the clamp to compress it slightly so the splines are tight. However and number of things inclkuding hanging a trans onl;y by the shaft while you undo the torque tube to trans bolts can break of one ear. Then under load it spins off the spines. The old very brown 1980 with 200 rwhp managed to break one tab. It never spun but made a clunk clunk as you got on and off the gas. Mark Anderson donated a good used trans (it does click in first) the common reverse idler issue but who uses first ? Thanks again !
Old 08-04-2010, 09:28 PM
James Bailey
It i spretty hard for the drive shaft to slip out since the rear clamp bolt passes thru a groove on the shaft.
Old 08-04-2010, 10:13 PM
mark kibort
5th gear means the entire gear and output shaft of the transmission, unfortunately, they are one and the same. if that breaks, you dont have any drive, let alone just 5th gear.
you could do this. start it again, and then listen as you put the clutch in. if you put the clutch in with it in neutral, and you hear things slow and stop spinning. (kind of a faint sound) that might be the torque tube slowing down and stopping if it is connected, which I imagine it will be. this will mean its broken at the rear which means 5th gear is toast.
Originally Posted by RPetty
Ok!
Still fix the gear?
Old 08-04-2010, 11:19 PM
RPetty
RPetty's Avatar
Its frustrating!!
Everything seemed great after the clutch install. Drove it a little in Pebble Beach (home).
Just barely got to 3rd gear and it quit.
Is it normal to no sound of gears crunching or something grinding??
NOTE** We did see metal shaving in the back peak hole.
Oh boy, this doesn't sound good
Old 08-04-2010, 11:26 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
This broken TT shaft made no noise when we tried to drive the car....
Old 08-04-2010, 11:55 PM
mark kibort
ewwwww! that brings back bad memories!
Yes, it can be silent. the only noise I heard was a slight clicking noise of the two pieces of shafts kind of hitting each other. if it is totally silent, that is kind of strange. Like I said, just turn over the engine, put the clutch in and see if you hear the slow down of the torque tube . should be a quick slow down sound.
Old 08-05-2010, 02:10 AM
RPetty
RPetty's Avatar
Lightbulb
Ok,
So let's say it is the tranny now...
Do you:
A) fix it as is?
B) upgrade?
If so:
How far and with what?
Ideas, comments?
Old 08-05-2010, 02:17 AM
mark kibort
just replace that 5th gear and rebuild the transmission, or better yet, bite the bullet and get an 85 or S4 trannie. that makes racing the 928 a dream!
you have the trannie, it was working, but how were the synchros? you might just be better off doing synchros and a new 5th gear. I dont know how expensive 5th gears are, but that might be an option.
I would be leaning toward a 85 gear box if I were you.
Ok,
Do you:
A) fix it as is?
B) upgrade?
If so:
Ideas, comments?
Old 08-05-2010, 02:27 AM
RPetty
RPetty's Avatar
Mark,
Are you saying these trannies are interchangeable?
Plug and play?
Old 08-05-2010, 02:35 AM
mark kibort
i changed my 84 with a 85 from anderson. I got a torque tube too, but I dont think I really needed it to fit. thats a List question, but yes, I think they are.
Mark,
Plug and play?
Old 08-05-2010, 12:42 PM
Lizard928
Lizard928's Avatar
if you have the 79 transmission/TT then you may have to notch the tt shaft for a later box to be able to bolt up.
Quick Reply: Track Day.... driveshaft slip out?
