High HC levels... (update)
so i this state (new mexico) old cars have to be tested every year for emissions, fine. i went to have it tested today just cuz, and low and behold im at 697 for HC at "high speed" 2500RPM ish, and 655 at 970RPM ish. so i take that i am running rich. how do you adjust that on an L-jet? is it a cat issue?
i dont retest for registering my beast till november. good thing i did it now.
Quack, says the Duc
Quack, says the Duc
Team Owner
test the O2 first back probe it, see if your getting .5 volts fluctuating while running and the engine warmed up
talked to my local tech, he thinks the timing is off. so i will swing by his shop tomorrow and check. what is the stock value for the FP? now i need a timing light.
Captain Obvious
Super User
Super User
Most mechanics will tell you whatever it takes to get your car into their shop. First check the O2 and go from there.
Basic Site Sponsor
Basic Site Sponsor
High HC is usually the result of a miss-fire.
You have any of the other readings? More info would help.
If you don't...start with the obvious. How old are the plugs (correct heat range and style) and what condition are the spark plug wires? Got any vacuum leaks?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Site Sponsor
Basic Site Sponsor
What was the CO?
CO was 0.02, Co213.2 and O2 was 2.41 . when i re did my intake i replaced everything from spider boots, to the rubber mounts for the throttle body. but i will try the brake cleaner trick to see if i can find a leak anyway, just to be sure.
Basic Site Sponsor
Basic Site Sponsor
Not enough fuel/intake leak.
Lean miss-fire, driving up the HC.
