High HC levels... (update)
#32
Lean missfire drives up the HC, every time. Doesn't matter if it is fuel pressure or a vacuum leak...it is still not enough fuel.
Glad you got it to work better.
Now add timing 2-3 degrees at a time, until you can make it "rattle" on a hot day. Take out the amount you added to finally make it "rattle" and you will improve the performance significantly. Just adding 5-7 degrees makes a huge difference.
( i have not had my coffee yet, so pardon the dumb question)
#33
Basic Site Sponsor
Basic Site Sponsor
No, until it pings. Advance it a few degrees, drive it for a day. Then a few more, driving it for another day. You will find a place where it is happy.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
