OB Brake duct conversion
So i have the front bumper cover figured out, and i got the ducts from a friend here in town, but what all do i need to change to add them? i know i need the front spoiler "vents" and some mounting screws, but do i need new fender support brackets and front fender splash guards as well? anyone got pictures of the ducts mounted?
Duc
here is what i got now,
Duc
Team Owner
OK so you want to add the S spoiler to your non S front end??you need the lower S fender supports, the lower control arm rubber air deflectors and clamps .
possibly the upper metal air deflectors that are bolted to the lower shock bolts. a longer airducting hose to alternator or relocate the end as the tube now has to run under the duct.
The front PU cover cut to fit the air intake grills,
the airducts and the airduct braces, the S spoiler,
the S fender block off plates, they are cut to fit around the airducts
