928 Forum 1978-1995
Sponsored by: 928 Specialists
Loose Wiper Arm
Old 07-13-2010, 05:17 PM
Tom in Austin
Tom in Austin's Avatar
Default Loose Wiper Arm
The monsoons the past few weeks have taken a toll on my driver's side wiper. It no longer makes a full stroke and I can lift up the arm and move it back and forth with little resistance - and no movement in the other one - as though something's come loose in the mechanism.
Old 07-13-2010, 05:18 PM
SeanR
SeanR's Avatar
Just one arm? Try to tighten it up a bit and see if that helps.
Old 07-13-2010, 06:13 PM
G Man
G Man's Avatar
Sounds like it may be slipping on the splined shaft it is attached to. I had a similar situation with my rear wiper. I ended up using a washer under the nut to be able to crank down a little tighter and that took care of my issue. Not sure if the fronts use the same attachment method.
Quick Reply: Loose Wiper Arm
