linkage Ball Socket
linkage Ball Socket
928s 1985
Little help,,, I pulled the photos from big dave and looking for the the part numbers for the full product or the link ***** to each side.
Not sure what its clled so please look at the pics.:
I looked at the Original Parts Catalogue but just can not find it, this is the last step for her to come to life
if you know where i can order that would be great too.
thank you Rich
Archive Gatekeeper
'pull rod' 928 110 719 01, maybe?
Yes, that's the part number - 928.110.719.01. It's on PET Page 105-00 item#34.
Rich, why do you think you need a new one? These ball sockets rarely fail, they usually just get rusted and the spring clips don't move. I've cleaned them out by spraying them with liquid wrench and a dremel tool with a thin wire brush end. It's certainly worth a try.
Also, your cam gears look very worn. If you haven't replaced them, I would recommend doing it sooner rather than later. Once the coating is gone they wear very quickly and start "cupping", which is not good for the belt. Same with the Oil pump gear and the main crank gear (not cheap!)
Basic Sponsor
Item is no longer available
I dont need the rod just the ball due to the Plastic inserts being cracked and not keeping the rod on the ball joints. I also beleave the threads are clockwise on one side and counter clockwise in the other.
I'll be back at the shop tonight.
Note the Pics are not of my car, they are from big daves car.
pics of what im needing
ok im a little closer but still need some help. the rod infact does have clockwise and counter clockwise threds. The pins are busted in/off the *****. i had one extra good ball that gos on clock wise but cant find the ball that gos on counter clock.
Dremel off the ball studs, then make up a rod with right & left hand heim joints & use
allen bolts with nylock nuts in place of the ball studs. If you just need ends for the cables,
consider getting rid of the fixed ball & using female metric heims & allen bolts
(thread size to fit cables) or if you can't find metric ones look into using an American
threaded one that you drill & put a metric thread insert of the correct size into the female end.
Something like a size 10- 32 heim should be big enough
Looking a little, I found this:
http://www.midwestcontrol.com/catdis...ort.php?pg=233
be sure you tell them you want the ball to be loose so you don't get a sticky throttle.
some of the heims are very tight.
Last edited by Jim Devine; 07-09-2010 at 07:11 AM. Reason: better way to do it- built in stud
Team Owner
if you have 2 good ball caps you could drill out the threads and JB weld one side to the rodmake sure to measure the rod prior to any machine work .
OR just get a used ball/ rod assembly from 928 INTL
928 Engine Re-Re-Rebuild Specialist
Look very simialr to these:- https://www.europaspares.com/FUEL_SY...INTS_3748.html
M5 threads. Also seen some in M4. Not visible that they come in RH and LH threads, but that can be overcome.
jp 83 EuroS AT 52k
jp 83 EuroS AT 52k
