Who can rebuild trans cooler lines?
That says it all, had a customer go to several hose places and it is a no go, but they are willing to put hose clamps on it or cut the line up and weld fittings on there. I am looking for a place around Atlanta that can do this, trying to get this car done by Friday and have a long way to go. |
Look in the Alpharetta phone book, there is a place near the mall, on maxwell road i recall, that built mine in the past. They specialize in hydraulic line assembly and rebuild.
Thanks guys, Micheal Murphy just gave me a local place that can do them, thanks Micheal. :cheers:
Greg Brown makes some "special" trans lines.
.......you can.
Rated hose and good clamps/fittings. |
Originally Posted by Tony
(Post 7714982)
.......you can.
Rated hose and good clamps/fittings. On my car, maybe, on a customers car, not a chance. |
Pretty much any hydraulic shop that caters to the heavy machinery trade can do it, Greg.
You can save a bit of cost by cutting off the fittings yourself, but make sure to mark which fitting goes where as well as the fitting clock position relative to the hose. I had my trans cooler lines rebuild a few months ago for less than $100. |
Originally Posted by Randy V
(Post 7715556)
You can save a bit of cost by cutting off the fittings yourself, but make sure to mark which fitting goes where as well as the fitting clock position relative to the hose. I had my trans cooler lines rebuild a few months ago for less than $100. I talked to a automotive hose place this morning and they said it wont be a problem, we shall see. |
Are the trans cooler lines and sleeves small enough to use a cable crimper? It would seem like a large cable crimper would be darn close. Greg, for grins and if you have a chnace, what's the crimped diameter of the installed sleeves? I could check the dies I have for power cable.
Originally Posted by dr bob
(Post 7715707)
I went to a local hydraulics shop.
Cost $65 and had them the next day. Good to 3500psi |
Originally Posted by Lizard931
(Post 7716503)
