Timing belt replacement trials and tribulations
1. I used the lip on the balancer - scary - but was very very careful and painfully slow at pulling it off.
2. The GTS does not seem to have the brown plastic clip my 86.5 had.
All ready to remove the t-belt.... Thanks for all the help.
Found the A/C connector after all.
Timing belt is off - the PS side pulley moved a couple inches clockwise. Normal, I hope.
Team Owner
its normal if you have the crank at 45deg. this position prevents the cams from pushing the valves into the piston tops
