928 Forum 1978-1995
Sponsored by: 928 Specialists
Cooling Flaps always closed
Old 06-11-2010, 06:55 AM
  #31
VCat
VCat's Avatar
Bought mini socket set to get to that tricky nut.
Removed nut A that holds arm B locked to the motor axle.
Removed arm B from the motor axle and opened the closed flaps, which pushes linkage C down.
Put arm B back onto axle, which was 180* rotated, and put nut back on.
AND NOW IT WORKS PERFECTLY!
Thank you everyone for helping me with this obscure problem.
Now I don't have to drive around with my flaps held open. Fnar fnar!
Pedant's note: I had already removed a nut that holds motor, now safely back on...
Quick Reply: Cooling Flaps always closed
