Motor Mounts - WARNING PLEASE READ
#124
Brad,
The MM's in your link is what I used to sell before the original company was sold to the India based company. They are now hollow and collapse hence the reason I do not sell them anymore.
We also do not sell rebuilt water pumps but that company in your link still does - go figure.
Roger
Roger
Remember I was new last year and may have made a few errors but so far so good.
I hope I have two of the good mounts because the engine is coming out and it would be a good time to replace them, but so far they seem to be strong.
God of all the things to screw up I would have thought the MM would be the last on the list.
Volvo has a good rep and you guys should be good with them.
I may pick up a set and install them when the engine is out just for ****s and giggles.
Glad you found a fix Roger. BTW could you post some of your 3rd coast pics at 928OC. I am sure that they would love to see what they missed.
Brad
#125
This is a very interesting article ! It is almost two years since the last post.
Is there any new information on the use of a Volvo motor mount in a 928 ?
Is there an advantage to the use of an OEM Porsche MM instead of a Volvo one ?
Is price the only advantage to using a Volvo MM ?
#127
Under the Lift
#128
Chronic Tool Dropper
Feedback from users over the last couple of years has been good so far with the Volvo mounts. I'm a big fan of the hydraulic-style mounts for their dampened movement. It makes the car more comfortable, while it eliminates any possible resonant movement that might happen with a hard-rubber or solid polyurethane mount.
My own car has genuine Porsche mounts in it now, and they are about 8 years old at this point. There's less than 6mm of compression on them in that time. If/when I need to renew them, I'll look carefully at the Volvo mounts as a substitute. By then, we should have a lot more group experience to draw on as far as lifespan/durability.
There are more than a few other threads on users' experiences with the Volvo mounts. A little bit of Rennlsit search effort will get you more info.
HTH!
#131
Roger...I still have a set I bought from you back in late 2008. Are they still good? They are still in my "to do" box. The metal has a golden Cadmium plate finish.
