928 Forum 1978-1995
Sponsored by: 928 Specialists
COLD AIR INTAKE NEXT LEVEL OF PERFORMANCE?
Old 04-13-2010, 03:21 PM
Tom in Austin
Tom in Austin's Avatar
Hey Tim, I guarantee I'll buy "up to 15 beers" at the next GTG ... lol!
Tom in Austin is offline
Old 04-13-2010, 03:41 PM
mark kibort
mark kibort's Avatar
Tom, its guranteeing that you will buy 3% of his body fluid, in beer.
could be up to 15 beers, depending on how big Tim is.
mark kibort is offline
Old 04-13-2010, 04:10 PM
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Erik N's Avatar
OK well then we can figure this out.
Figuring Tim is an averege 928'er enthusiast size of 200 lbs
Figuring Tim has an average male body fluid of 60% (Tim is a guy, right? females average 50%)
So then Tim's beers = 200#x60%x3%= 3.6 lbs of beer
Figure beer weighs 8.35 lbs/gallon then 3.6/8.35=0.43 gallons of beer
0.43 gallonsx64oz/gal=27.5 ounces of beer
That seems entirely reasonable!
OK back to paramedic studies now
Erik N is offline
Old 04-13-2010, 04:20 PM
tlsmith1999
tlsmith1999's Avatar
hmm, that would work out to be just shy of 2 bottles of beer for me at my actual weight.
tlsmith1999 is offline
Old 04-13-2010, 04:29 PM
inactiveuser1
inactiveuser1's Avatar
Yep, we have a company built around the concept. The lastest eRAM does have near 4000watts, and is built on DC brushless motor technology (like the EDFs you show on the video). This system does require a separate set of small odessy-like batteries for a 24volt system. There is a new DC brushless system that is near 1000watts, near the same as the previous-current eRAM, that runs on DC brushless and is much more efficient.
It is very difficult to create substantial pressure with an axial flow fan, but it is absolulely possible. Much of the gains of the eRAM were due to reducing pressure drops in the intake air box, with some pressurization of the airbox itself or intake tube if it is sealed.
Mark
Mark,how long before we can get you to put one of the 4000 watt systems on your car,anything in the works?
inactiveuser1 is offline
Old 04-13-2010, 04:40 PM
mark kibort
I think this is is. Its the prototype and was being tested on some mustang back east from what I remember. Ill have to see what stage it is in now.
Old 04-13-2010, 04:50 PM
inactiveuser1
Mark,
Thanks for looking into it,will see on the 120mm ones if they are with or without brushes.If you check it out see what boost might be 1.5 to 2lbs?
Old 04-13-2010, 05:46 PM
Hold On
Hold On's Avatar
What was it that P.T. Barnum said.........
Hold On is offline
Old 04-13-2010, 06:16 PM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Sooooooo .... do you mount these things in the cold intake tubes? If yes and they are only used at WOT, seems to me they would block a lot of air flow for the majority of time you are not at WOT. Orrrr.... do you configure a seperate cold air intake system that has servos that block off the regular intake tubes? Someone needs to diagram for me how this system is implemented.
S4ordie is offline
Old 04-13-2010, 06:17 PM
mark kibort
the pressure is critically dependent on the impeller "rotor" style. the one in that video will never make much pressure, but the 6-8 bladed fan as we have shown on the picture, will. pressure is near 2psi. I dont know if this is the large or small version, but I thought one of them was to fit in the 4" intake tubes that the mustang guys were using.
mk
Mark,
Old 04-13-2010, 06:20 PM
mark kibort
hmm, funny, you just asked the most common question over the 15 years we have been making these things. The quick answer is no. You do understand that you have a "Throttle" body, right? "Throttle" means "choke". when you are NOT at WOT, you have the throttle "choking" off the air flow, BY design. if it didnt, you would be running at max power all the time. Besides the point, the air flow of the eRAM on a flow bench is near the same flow as a 3" straight pipe, so its not a factor.
mk
Old 04-13-2010, 06:44 PM
LightStriker
LightStriker's Avatar
Surprised those electric fan keep coming back...
The only thing I remember from them is the guy who got parts in his cylinder, destroying his block in the process, cuz the engine normal aspiration at higher rpm was more than what the blade could take.
LightStriker is offline
Old 04-13-2010, 06:54 PM
Jim M.
Jim M.'s Avatar
That's why you find them on so many race cars and the factory high performance models.
Jim M. is online now
Old 04-13-2010, 06:57 PM
LightStriker
And BTW...
CAPS LOCK IS CRUISE CONTROL FOR COOL! NOT!
Old 04-13-2010, 07:11 PM
mark kibort
no, that was because the unit came apart due to manufacturing issues at the time. a V8 5 liter engine requires about 550cfm at 6000rpm, the fan puts out near 1000cfm. (confirmed and tested at Sema on a powerflo flow bench)
I used mine for 10 years, and still have the original unit. its more limited by engine output than anything else. at 250rwhp, it adds 5-8 hp. at 200hp it adds 10hp. at 300 t 350rwhp, there are little gains, but the shape of the curve can change slightly to be worth it. (thats on the very old version) The new version can help the higher hp cars, but it costs $$$$
Quick Reply: COLD AIR INTAKE NEXT LEVEL OF PERFORMANCE?
