Twin Turbo 928 fixed and back out there terrorizing the streets! - Page 4 - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Reload this Page >
928 Forum
Sponsored by: 928 Specialists
Old 05-21-2010, 07:06 PM
  #46
ptuomov
Super User
ptuomov's Avatar
Originally Posted by Hacker-Pschorr View Post
When in doubt data log, data log, and data log some more. Still baffles me how little people actually measure. Install a fast acting temp sensor after the IC, if the temps are within the desired range, no need to go changing anything. I know some who would go as far as measuring the pressure, velocity etc... of the air in the chamber before the IC.
The plan is to take a number of measurements. Any further ideas would be greatly appreciated.
Among the many sensors being installed are:
- Turbocharger speed sensor that measures the rpm of the turbine-compressor shaft. This is useful for optimizing bypass valve spring load for shifts etc.
- Outside temperature sensor inside the IC duct. This is useful in computing the intercooler effectiveness.
- The pre-turbine exhaust back pressure. This is useful in calibrating the simulation software to match the exact turbine (EAP can't accurately match turbos without these data) and in selecting the camshaft profile.
I did independently confirm the presure differential between the wheelwell and the bumper face separately using silicon hoses and a manometer. That was a one-time job on route 2. John had of course done this earlier, but I just had time to kill.
ptuomov is offline
Old 05-21-2010, 07:14 PM
  #47
Hacker-Pschorr
Super Moderator - Cracklin' Rosie
Hacker-Pschorr's Avatar
#1 suggestion that comes to mind is test the temp senders before installing them (heat gun / hair dryer etc..)
Two reaons.
1. Avoid installing a broken one
2. Make sure they are sensitive enough.
Most cannot react fast enough for an accurate reading of intake air. Any old water / oil etc... sender will not be accurate.
I'm still playing with a few myself. I just had Todd install two different units above my TB in the plenum. We'll see how they compare. By the time I'm done installing sensors (not until after SITM) I'll have at least 5-6 intake air temp readings.
Hacker-Pschorr is offline
Old 05-21-2010, 07:20 PM
  #48
ptuomov
Super User
ptuomov's Avatar
I'll only go that far if the intercoolers aren't the total overkill that I expect them to be. As you said, no need to get fancy then.
I think you could adapt Garrett's turbocharger speed sensor to the centrifugal supercahrger unit. I don't know much about belt-driven stuff, but I vaguely recall that centrifugal units need a belt that can slip a little. Getting the actual speed reading and comparing that with the engine speed will allow you to compute the belt slippage and also to exactly pinpoint the location on the compressor map.
ptuomov is offline
Old 05-24-2010, 11:59 AM
  #49
ptuomov
Super User
ptuomov's Avatar
Default Photo of intercooler installed
I am staring to feel good about THE GAPING HOLES IN THE BUMPER...
ptuomov is offline
Old 05-24-2010, 03:21 PM
  #50
tveltman
User
What sensors are you using to monitor EGT and exhaust backpressure? I would be interested in getting a set for myself if you have details. Actually, details on all of your sensors would be delightful. Thanks!
tveltman is offline
Old 05-24-2010, 03:48 PM
  #51
ptuomov
Super User
ptuomov's Avatar
Right now, I just have ports for the exhaust back pressure measurements. After turbo is not a problem, but pre-turbo may require a cooling tube before the sensor. In other words, I am not sure yet what I'll be using and if I may be able to avoid the cooling tube.
The turbocharger speed sensor is from Garrett. It's on their web site. Install's to the compressor housing.
The whole data logging system beyond John's standard product is still work in progress.
ptuomov is offline
Old 05-24-2010, 05:12 PM
  #52
tveltman
User
If it helps, I think I read about Louie Ott's individual cylinder EGT monitoring system. I can't find the post right now, but he used some sensors hooked up right out of the manifold. I would use those, if I could find the link...as for pressure, they must exist somewhere...
tveltman is offline
Old 05-24-2010, 05:32 PM
  #53
ptuomov
Super User
ptuomov's Avatar
EGT monitoring is old school. New school way is to use those ports to monitor lean/rich condition, especially if you have an aftermarket ECU that can do clyinder-specific fuel trim. I think that requires another eight tubes down there, since wideband o2 sensors will not live in the cylinder head exhaust port.
ptuomov is offline
Old 05-24-2010, 05:48 PM
  #54
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Like this?
https://rennlist.com/forums/928-foru...ds-garage.html
Rob Edwards is online now
Old 05-24-2010, 05:57 PM
  #55
tveltman
User
That is unbediculous...
tveltman is offline
Old 05-24-2010, 06:02 PM
  #56
BC
Have you found an aftermarket ECU that has Fuel trims per cylinder on a load basis? Instead of just on a global percent basis, which does nothing if the intake is not perfectly matched to each cylinder. That does not exist in the S4 intake manifold, and Todd found that some had over 20% difference, up or down, according to the revs and load.
When I found this out, I asked questions of the people involved in the ECU market. I found two, and two only:
Autronic (which Todd uses)
Pro EFI 128*
* This is an untested system as far as I am concerned, but its promising.
BC is offline
Old 05-24-2010, 06:21 PM
  #57
SQLGuy
User
SQLGuy's Avatar
Pro EFI 128*
Megasquirt with MS2Extra will do it for a four cylinder running sequential injection (separate percentage cylinder trim map for each injection channel). I would think the logic could be extended to eight cylinders, but you'd need the sequencer/MSIII which is not yet available, or you'd need two Megasquirts running the MS2Extra sequential code... one for each bank; which is weird, but theoretically feasible.
SQLGuy is offline
Old 05-24-2010, 07:08 PM
  #58
BC
Percentage change in trim does not factor load.
BC is offline
Old 05-24-2010, 07:39 PM
  #59
ptuomov
Super User
ptuomov's Avatar
Originally Posted by Imo000 View Post
Looks very nice! Those downpipes must be one heck of a tight fit. One side for the narrow and the other for the wideband O2?
There are four bungs, two pre-turbine and two downstream of it. The exact configuration of what goes where, whether the narrowband is simulated from wideband, etc. is open. Initially what you say is one likely configuration. In the longer run, for tuning / logging one is probably going to be pressure sensor. Que sera sera.
Yeah, it's not clear from the picture how big the face of the core actually is. I just thought I would mention it since there is a ton of information and it is easy to overlook something simple like that.
The latest photo should again communicate the perspective a bit.
Originally Posted by Rob Edwards View Post
That's what I had in mind. That's more of a personal R&D lab than a car meant for a customer, though.
Yes, but it's a lot better than nothing.
ptuomov is offline
Old 05-24-2010, 10:19 PM
  #60
Lizard928
Lizard928's Avatar
I would caution against putting any O2 sensor pre-turbine. There is too much heat there and it will cook them in a BIG hurry. That is even with a copper heat sink.
Lizard928 is offline
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
