Twin Turbo 928 fixed and back out there terrorizing the streets!
#2011
I think if you get a Pectel MQ12 you can use some fancy sensors from Omega to do advanced knock control strategy, or Cosworth will help you.
If you have a Motec 800 or better, then you can use the Motec knock controls but the hard part is programming the detection parameters. Motec may help you but..... they may send you to Sakata..
Ion sensors may be able to be used with the MQ12 as it has FGPA chips and can process the speed of the I/O items....
Just a thought....
BTW the MQ12 can handle 22k rpm
Just a thought....
#2012
You mean FPGA as in field programmable gate arrays? That would mean going at it from first principles... note that I’m looking for a way to detect pre-ignition, not just spark knock.
Just a thought....
Just a thought....
#2013
Who said that Porsche drivers had small ones?
Who said that Porsche drivers had small ones? The piston oil squirters from transaxle Porsches are about twice as big as those in BMWs. Maybe they meant the air cooled ones?
#2014
Squirters
The reason I’ve recently been more interested in pistons, piston oil squirters, ring widths, etc. is that we are pretty close to being able to run real test runs with this blue engine to learn at which rpm range John’s turbo system really wants make power efficiently. If the answer is low rpms, such as 3500-6300 rpm range, then the best engine solutions go one way. If the answer is high rpms, then the best engine solutions are completely different.
For example, if the answer is that the most efficient way to make power is high boost at 5800 rpm, then the engine needs to be developed to look even more like a diesel engine. In contrast, if the answer is lower boost at 7500 rpm, then the engine needs to be developed to look more like Mike Simard’s, Andy’s/Greg Brown’s, and Todd Tremel’s short runner higher rpm engines. The first option entails heavier pistons, thicker piston rings, taller ring lands, higher compression height, less concern about oil spray pattern, windage, and piston pumping pulses, and more of a chance to retain a wet sump oiling system, compared to the second option.
#2015
It’s all coming back to me now. Keyboard bullies from the 1st decade of the millennium return! Personal vendettas! Threatening offline communications! Drama!
Like I said - for everyone watching these are nasty, nasty people. And this one hunts people down on a personal level and sends them threatening letters because... well, that’s what they do.
And for the real kicker - this shows up at my workplace. Smooth. Awesome stuff.
And for those still watching: (From 2008, from a former moderator who serves some awesome bloody Mary:
https://rennlist.com/forums/928-foru...ml#post5149825
#2016
I did, however, really like the car shaped paper clips.
#2017
You configure the I/o to read the sensor output and other conditions to determine and detect pre-ignition and make the adjustments before the detonation happens. It's a thin line, but the MQ12 is the only ecu short of the newer F1 type ecu's that has fgpa and can handle these interesting computational exercises.
As I mentioned prior, to use the Motec setup it also requires custom programming to get it to work properly. Which means talking to Motec to get a Motorsports engineering pro to do diagnostics and program the knock module and calibrate the integration of the ecu main/secondary tables and control functions. Motec doesn't offer direct support like this, but they will probably refer you to Sakata or Fischer or someone similar.....
Cosworth will also do the same remotely if you buy an MQ12 or whatever their newest ecu is from PI/Pectel. The MQ12 has telemetry as an option. As this is a maximum exercise theoretical construct, I'd suggest the MQ12 with calibration help directly from Cosworth.... Why muck around if you're going after maximum benefit.....?
Yes you can...
be a cossie customer
#2018
Received 1,543 Likes
Danger!
Danger Will Robinson!
Streisand Effect Proximity Alert!
#2019
Yes, that kind of FPGA...
Yes you can...
Yes you can...
#2020
With regard to pre-detonation: what are the measurement data and devices? Vibration via the knock sensors? Differential temperature? Something else? Time constants of proposed measurement techniques vs required control time constant? Papers?
#2021
https://www.sae.org/publications/tec.../2017-01-0792/
Way above my abilities to implement, for sure.
This is really only necessary for the race gas runs. As Jim Corenman noted in another thread, with pump gas pre-ignition leads to knock and the regular knock detection system can measure this.
#2022
Let me get the LH 2.3 run first (with a huge help from UK, KY, and CH) and once that and hardware all in good running order, then I can ask another friend for pointers on FPGAs and whether that's even in the realm of possibility. He's trading stocks with FPGAs which are faster and less space consuming than general purpose chips for some particular tasks.
Someone I know runs Flex Logic, interesting stuff....
#2023
It's either ion sensing from the spark plug or a dedicated cylinder pressure sensor:
#2024
In response to the non-technical content that in my opinion doesn't belong to the thread that is appearing and disappearing without any rhyme or reason that I can understand, I'm going to close the thread.
#2025
A quick update
We took two steps back and two steps forward over the last year. The original transmission blew into million little pieces a year ago and the last twelve months were spent acquiring and building some transmissions. We've got one in the car now and another one waiting to go in when that one blows up. NEt forward progress is transmission cooler setup.
In any case, the car is back to being drivable. It's going on the dyno next week. Testing will continue from the same spot where it ended in 2018.
