Twin Turbo 928 fixed and back out there terrorizing the streets!
#1867
#1868
Captain Obvious
Super User
Super User
Might want to consider installing something removable over the intercoolers (bug screen or something similar) to ease the cleaning process. The 996 has the radiators with ducts like this and everything from cigarette butts, to tire chunks and an amazing amount of gravel collect in the radiator fins becaseu the ducts have no space at the bottom for debris to fall out.
#1869
#1870
Rainman
current GT2 has mesh all the way flush with the bumper for that reason too.
even recessed slightly gives a "shelf" for stuff to accumulate on against the mesh.
put a hinge on it so you can get your red bull cans out
#1871
Big a$$ oil cooler
This is the big oil cooler, probably double the stock GT cooler volume. Plus for thermal stabilization, the oil gets run thru one of the radiator end tanks, too.
#1874
I don’t know the exact model, and it’s not my IP to give out as I didn’t do any design work on that part. That said, you can probably look at the video, measure the space, and then guess from the Setrab catalog which slimline coolers those are.
John’s close to firing this thing up. He just tested fuel pressure!
To be completely honest, I’ve really been slacking on all car project related stuff recently. While John has been working on the car over the last three weeks, I’ve been doing some traveling. London, Vega$, Turks and Caicos, Vermont. Hard living but not a hard life....
