Just perfect....
Time to heat it up, use some penetrating oil and get the extractor kit out.
Team Owner
use some PB or Kroil on it with some torch heat use wet rags so surrounding areas dont get damaged then weld a nut to the top of the stud then unscrew it.
This will work better if the coolant is drained as the aluminum will heat up faster and expand more with the welding heat
