928 Forum 1978-1995
Sponsored by: 928 Specialists
S/C Pipe reduction ?
Old 02-08-2010, 02:46 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,230 Likes on 1,258 Posts
The 2 into 1 used on certain Murf kits (like mine) is a dual 3" into a single 4" using a different airbox.
The gain is with the 4" opening in the airbox, not the dual intakes. The only reason we went with dual 3's over a single four is fitment issues.
Old 02-08-2010, 09:28 PM
davek9
davek9's Avatar
Yep that set up 4" into the two 3" worked GREAT on Brian's '87 w/Murphs Stage III
Wow.. I think he was getting 12 PSI of boost
I have his car in the garage; I'm doing a pan gasket and a "little" list of other clean-up and stuff on her. Can't wait till he takes me for a ride this spring
Old 02-08-2010, 09:48 PM
inactiveuser1
inactiveuser1's Avatar
Originally Posted by Tampa 928s
I found this on E-Bay:http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Thanks for the info!
But back to my initial request if I was to use the Maf as a puller will the reduction in TB size cause a air flow reduction? I did loose boost the last time I did this but before I go out and purchase the correct hardware I would like to know.
Here is a 4" to 3 1/2" if needed.
http://www.summitracing.com/parts/SPE-9741/
3 1/2" to 3 1/2"
http://www.summitracing.com/parts/SPE-9571/
Old 02-09-2010, 05:46 AM
stuartph
stuartph's Avatar
Erik
Does tim offer this 4" airbox for sale
Old 02-09-2010, 09:49 AM
hacker-pschorr
Originally Posted by stuartph
Erik
You have a PM
Old 02-11-2010, 07:39 PM
inactiveuser1
Interesting read on intake air etc at:
http://www.kennebell.net/supercharge...th/mammoth.htm
Quick Reply: S/C Pipe reduction ?
