Nothing is ever easy. (Stripped 02sensor and bung)
Simple job...lift car..drop exhaust..xpipe...install cats...SMOG....DONE...
a couple hours tops.....done it numerous times over the years,
until you try to remove your 02 sesnor this time from the Xpipe.
How in gaaawds name does a thread get cross threaded on the way out?!?!!??
my o2 sensor is destroyed..(at least it wasnt the Wideband for my LM1).and now the bung in my Xpipe doesnt look the best either.
Anyone have any luck finding a M18X1.5 tap at any "local" stores? I can chase the threads in the bung and it should be OK. Last thing i want to do is cut out and reweld a new one on my pretty ceramic coated Xpipe
I really dont want to order one online and have to wait until next week now.
If you can clean up the threads on th e old O2 sensor you could then file some longitudinal grooves in the threads using a triangular file (keep the trailing edge of the groove radial ) use that as thread chaser.
Has worked for me in similar situations.
Tony...........if you cant find a thread chaser of the correct type buy a cheap generic O2 sensor and cut (file) groves in the threads every 90 degrees and create your own chaser.
Stereo Jon
Stereo Jon
Captain Obvious
Super User
Super User
I'm pretty sure the O2 and a standard size spark plug are the same size a thread pitch. You can use that to make thread chaser. OR.... find the local Harbor Freight and they should have an O2 thread chaser. Carbon build up at the end of the O2 threads is probably what caused your problem. I hope this helps....Good luck.
for future searches on the topic
http://www.harborfreight.com/cpi/cta...emnumber=66417
http://www.sears.com/shc/s/p_10153_1...=thread+chaser
Nice find on the thread cleaner.
Team Owner
look on Amazon for a new O2 sensor its about 67.00 plug and play just do a search
I did the same thing on mine 2 weeks ago. I just retapped the theads on the bung. The M18x1.5 tap should be available, keep looking. I borrowed one from a friend but I saw one at the shelf at Carquest as well. As far as the galled theads on the 02 sensor they weren't damaged to much and went on smooth once the bung threads were clean.
Mmerlin the Amazon.com 02 sensor I bought for $67 are now $72 so still a good deal...
https://rennlist.com/forums/928-foru...en-sensor.html
Administrator - "Tyson"
Could always pack some JB weld into the hole
that's exclusive to my block only ; )
anway..fixed. HF had them for 1.99 but not in stock. Sears had them on the shelf for 6.99. I picked up a bosch o2 sensor @ autozone also for 35.99 (part 13913)
I chased all of my bungs...hahaha...every thing threads in nicely now.
awaiting smart a$$ remarks. : )
