928 Forum 1978-1995
Sponsored by: 928 Specialists
86.5 T belt warning wire?
Old 01-25-2010, 10:19 PM
fredfox
fredfox's Avatar
Default 86.5 T belt warning wire?
I am trying to figure out where it hooks up, (the wire to the warning light on the tensioner) It was unhooked on my basket case winter project and I am trying to make it right.
A picture would be nice. I have tried searching to no avail.
Thanks, Fred.
Old 01-25-2010, 10:54 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Look for a small round button behind the oil dipstick. Wire from the warning computer runs to that round connector, then from that rubber button connector, inside the belt cover a short wire runs to a 1/4" flat spade connector on the tensioner arm.
Old 01-25-2010, 11:18 PM
fredfox
fredfox's Avatar
Thanks, I thought it went to the arm.
Old 01-25-2010, 11:31 PM
WallyP
WallyP's Avatar
There is a flat metal strip that runs up the arm to the nylon bush and spring unit - make sure that it isn't broken. It was replaced by a black wire on later models.
Old 01-26-2010, 11:33 AM
SteveG
SteveG's Avatar
Porsche replaced the flat connector b/c the motion it receives can twist and many failed; while the wire obviously can withstand that. I had a new flat one break w/i a few thousand miles. I did this solder job (don't laugh - probably can't see the detail, but the solder is attaching an "X" of 2 braided wires which can bend and/or twist. This worked til I installed a Porker. If you are replacing it, get the wire.
Old 01-26-2010, 12:13 PM
fredfox
fredfox's Avatar
I will take a picture of what I have and post it tonight. Then you all can tell me what I need.
Old 01-26-2010, 12:31 PM
Calgary Ole
Calgary Ole's Avatar
Go down to my thread "TB Job Questions" post #32. There is a picture of the harness that goes through the cover onto the warning switch.
Old 01-26-2010, 06:34 PM
fredfox
fredfox's Avatar
Ok, Here is what I have, there is no metal strip just the tensioner and a bolt hole in it. It is an 86.5 that I got from an inlaw and it had a tbelt and wp failure. It was apart when I got it. I have repaired the heads and such, now I am reassembling.
So, does the wire just go to the tensioner? It has new bushings in it now.
Old 01-26-2010, 06:41 PM
SeanR
SeanR's Avatar
Should look like this
Old 01-26-2010, 06:46 PM
fredfox
fredfox's Avatar
That does not look like it is from an 86.5. _ 85 and 86 are different.
This is 87 and up.
And 85-86
The 85-86 has no wire. So, does the wire go directly to the arm?
Old 01-26-2010, 07:08 PM
SeanR
SeanR's Avatar
The one in the picture is an 87 and yes, if you are running a 32v car, it will have that.
You can clearly see in your picture that the screw holding the wire connector is gone.
Old 01-27-2010, 11:08 AM
SteveG
SteveG's Avatar
https://rennlist.com/forums/928-foru...uestion-2.html
The above thread should help. First post has WSM schematic. Post 19 the 3rd, 4th and 5th pic down shows a spade at top of tension arm. A connector w/female spade goes from there to the TB cover. The button w/red O-ring (#3) plugs into the cover. The value of dealing with 928 Int'l or 928 Specialists or Roger Tyson is they know what you need. HTH.
Quick Reply: 86.5 T belt warning wire?
