If one wants to monitor O2....
The air/fuel gauge just tell you if the car is rich or lean and fluctuates irradically.
Widebands give and actual Air Fuel Ratio reading and usually have a log you can download.
If you are tuning enough to look at the AFR you need the increased accuracy of a wideband.
You need a wideband sensor, a wideband controller and a wideband-compatible gauge. A narrow-band gauge will not work with a wideband sensor.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
Dan
narrow band (stock) O2 sensors work on a 0-1V with 14.7:1 AFR (stoich) being .5V They are ONLY accurate at stoich.
Wideband sensors such as the bosch LMU4, require a wideband controller, or a computer (like VEMS) which you can then do a free air calibration of it every now and then to ensure its accuracy.
All wideband sensors/controllers work on 0-5V and are accurate from 9:1 AFR to 19:1 AFR (give or take a bit).
However all wideband controllers have narrowband outputs so that you can use them with stock computers and just have the WB signal going into a datalogger like the LM-1.
So YES you can use your narrowband AFR guage with a wideband controller. And it will be more accurate than with the normal narrowband, but not nearly as accurate as a proper WB guage.
Colin, as you know I have installed the EMC system.
How can I tell which O2 sensor I have.
On my ENC laptop dash the AFR seems to move from the high teens to the high 9s.
right now (still tuning) my Idle is around 13.5
