The 944 uses the same relay - #944 615 113 01. They can be found on eBay and other places. I might have a good, late 944 around, but I will have to look. It could be a good back up for you. Michael
May I ask what makes you think they are the same? I'd like to think if they were Porsche would superced the 928 number to the 944 number.
I have not personally interchanged them so I probably should not comment. I probably read it somewhere on the 944 board at some point.
I can put them side by side, photograph them and post them on Sunday night. Since I do not have AC in my 944 and I have an engine-less 928, I cannot actually test them. My apologies for passing along untested info.
Thats an understatement.... totally different functions
I don't quite see what the exact 31b function is... the 31b is a speed signal - the same one that the fuel pump relay uses so it only stays on when the engine is rotating.
I'd assume here its used just as an AC disable until the car is running (to keep the AC clutch disabled during cranking...?) would seem more obvious to do this some other cheaper way - eg power the relay between 15 and starter solenoid signal - Porsche did this frequently on later models for disables during cranking (for other things).
Any one know for sure what the function is (eg when is the AC clutch disabled).
I'd be inclined to figure this out and rewire it to be able to use a standard 53b relay.
Alan
Looking at the diagrams, that was my guess also. I need Doc Mirror to double check me, but I am also thinking it wouldn't be too hard to do a 53 in there.
Thanks. I will stop guessing and start looking through my relays for one like the 928 AC relay. That 928 one looks pretty basic. Maybe I will find an available replacement.
Keep looking guys I need AC as it's so frigging hot here in Texas.
Here's a few pics of what the inside looks like on the 928.618.105.00 relay. This relay was in the car when purchased and didn't work. Tried resoldering the joints ala cruise control box but still wouldn't function. Ended up running some short jumpers from the CP to a standard relay, worked fine until I picked up a proper used working relay when BB500 was parting out his '79.
Maybe designed to cut out the AC compressor at high rpm?
