928 Forum
Sponsored by: 928 Specialists
Porken's 85 chips- Awesome!
Old 02-16-2010, 09:11 PM
  #121
PorKen
Inventor
PorKen's Avatar
Originally Posted by svp928 View Post
Wow, Ken, thats really nice- is this the same chipset you sent me last?
I hoped the last update would be the good for a while, but I found when I transferred the X-pipe and all my logging stuff over to the '85 that the WBO2 had been reading nearly 2 points leaner than actual! I had the injectors flowed, they were OK, and I had recalibrated the LC-1 often. I think it may have been the initial warmup calibration of the LC-1 that was off.
I chased my tail because of that (unknown to me) richness for a myriad of side effects, but I guess it was good because I learned a lot.
The new chips are verified against the dyno wideband (tailpipe shows ~0.5 AFR leaner than at the X-pipe), and feel even more powerful than before.
I'll work my way back through the list and update everyone.
BTW: In order to save space on the chip label for more info, and because I was optimistic before this dyno run, I registered 'S300s.com' to print on the second line. IE. S3, 300s at the wheel!
PorKen is offline
Old 02-16-2010, 09:18 PM
  #122
PorKen
Inventor
PorKen's Avatar
Originally Posted by Dannyfumi View Post
Ken-
Those are incredible numbers! So at the crank its about 375hp?
Danny
That's a little optimistic, I think.
It's a numbers game, but if you use 15% for the manual, 300 SAE RWHP / .85 = 353 CHP. 65 CHP over the stock 288!
Not too shabby! And, basically any S3 5-speed should get these kind of numbers with just an intake refresh and X-pipe, which is cool.
PorKen is offline
Old 02-17-2010, 04:21 AM
  #123
Darklands
User
Darklands's Avatar
Ken,
fantastic work!I think it┤s good timing that my 80 mm trottlebody is in a few days ready. ]:-)
A little bit more air in the intake should help!
I┤m very exited.
Karsten
Darklands is offline
Old 02-17-2010, 07:18 AM
  #124
Mike Frye
Craic Head
Mike Frye's Avatar
Originally Posted by PorKen View Post
BTW: do you still have the '85 cat-back?
Even with the pumkin mod, it is definately a restriction. I keep having to tap the cat-back back into the X-pipe after all the WOT runs I've been doing!
Sorry, I missed this question last time. Yes, I've still got the '85 cat-back and I had to have it welded to my cats because it kept blowing out.
I'm not sure what I can do because I don't want it to be any louder than it is because it's my daily driver.
Was hoping to try a set of electric exhaust cutouts (open for dyno or track days, closed for the street) but it doesn't look like the budget will support that this winter.
I'll paypal some more cash for shipping when the new S300s chips are available. Let me know.
BTW- GREAT dyno run! Congrats. What a huge improvement over stock. Nice work.
Mike Frye is offline
Old 02-17-2010, 12:48 PM
  #125
svp928
svp928's Avatar
Well damn. Now I need an x-pipe.....
Good work, Ken! On the "s300", also..
Steve
svp928 is offline
Old 02-17-2010, 01:17 PM
  #126
PorKen
Inventor
PorKen's Avatar
Something is limiting the top end. I started logging the EZF MAP sensor (pin 21, 0-5V, lower=vacuum). At 2000 rpm, manifold pressure is highest (~atmospheric), but steadily decreases (=vacuum) towards redline. I'm not sure if it's the undersized exhaust, and/or a restriction in the TB, housing, airbox, or inlet tubes, and/or the stock cam timing.
Log of dyno run.
80% injector duty at redline at 55psi.
Note how injector duty closely matches the HP graph.
PorKen is offline
Old 02-17-2010, 01:53 PM
  #127
Darklands
User
Darklands's Avatar
Is the drop from 4,61 v to 4,39 v signifcant ?
Maybe the computer cuts the fuel supply at high rpm because the MAF readings say not enough air.
Bernd has cams with more lift but no x and I a 80 mm tb and the same setup as you.The 2 different dynoruns will be interesting.
I wish a HP curve like the black one! ;-)
Old 02-17-2010, 02:42 PM
  #128
anonymousagain
anonymousagain's Avatar
Wow Ken, so the two Dyno runs were 287/290 before and 310/306 after, and your details indicate the only changes were
intake refresh, cleaned stock injectors, atmo crank venting, new stock air filter
Since you stated the injectors seemed okay...new filter helps a little...atmo crank venting maybe a little...is the intake refresh really where all the missing power was hiding? 23hp is a TON!!!
anonymousagain is offline
Old 02-17-2010, 02:53 PM
  #129
dr bob
Chronic Tool Dropper
dr bob's Avatar
[/I]
Ken, a restricted exhaust would cause the MAP slope to go the other way, ie: higher as RPM's increase, as pumping efficiency drops. Your slope suggests intake restriction upstream of where the pressure value is picked off.
dr bob is offline
Old 02-17-2010, 03:03 PM
  #130
PorKen
Inventor
PorKen's Avatar
There's a little 'puffery' there if you look closely.
The second dyno sheet is in STandarD correction with smoothing of 2. (STD correction is based on a higher ambient temperature.) If you look at the graph in (SAE with 5 smoothing), the proper comparison is 287/290 versus 300/298. 13 rwhp is still a nice improvement!
I did tweak the chips a little too, but not so much at high rpm, so HP was mainly from the intake refresh, etc.
The injectors I had flow tested were on my '86.5 (Ford type). I had the stock injectors cleaned on the '85 for the second dyno run.
PorKen is offline
Old 02-17-2010, 03:22 PM
  #131
svp928
svp928's Avatar
What did you do to the intake to refresh it? What change did you make to the vent sys to go to atmo?
I agree that the drop in MAP is because of a flow restriction somewhere....
svp928 is offline
Old 02-17-2010, 04:21 PM
  #132
dprantl
Super User
dprantl's Avatar
Forced induction would solve that problem
Dan
'91 928GT S/C 475hp/460lb.ft
dprantl is offline
Old 02-17-2010, 07:22 PM
  #133
PorKen
Inventor
PorKen's Avatar
R&R with '85 paper gaskets
Smooth casting bumps in TB/MAF housing
Injectors cleaned, new caps/o-rings/filters
Grind out thick layer of black crust on intake legs
Smooth casting bumps of last 2" of intake legs (surface left rough)
Hose straight from left plenum to brake booster
All (3) TB/MAF housing crank vent ports filled flush
All crank vent hoses deleted, including venturi Y-connector
Cam cover ports capped with 5/8" heater hose blockoff caps
Two 13mm ID hoses from oil filler tower ports dropping into a 5-quart M1 jug
I didn't have time but I mean to make a plate to replace the oil fill tower with a 1"+ hose outlet to exit under the coolant bridge (large cave on pax side) for both oil filling and venting. I would like to put a hose blowing cool air (via a bilge blower) into the space where the oil filler tower was, to cool the underside of the intake and MAF.
The EZF MAP sensor gets it's vacuum from the 7-way splitter, which goes to a port just above the throttle plate. It would make sense then that it's before that point. Throttle plate<-housing<-MAF<-filter<-airbox lid<-tubes.
PorKen is offline
Old 02-17-2010, 07:31 PM
  #134
PorKen
Inventor
PorKen's Avatar
Dude, I'm all motor...
...until I get me a turbo or sumpin' up in thar.
PorKen is offline
Old 02-17-2010, 07:58 PM
  #135
svp928
svp928's Avatar
Ken, thats a bit-o' work there..
I am making a housing that goes where the orig oil-fill-vent housing is for someone else, maybe he will share and it can be made like you want it..
All motor for me, too....
svp928 is offline
Quick Reply: Porken's 85 chips- Awesome!
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
