Rotating direction
Rotating direction
Can someone remind me the proper direction to rotate the engine by hand and the size of the crank bolt. I'm thinking it's clockwiase as looking from the front, but I don't dare just guess.
I don't know what dives me more crazy, looking for things with search, or trying to find what i need in the CD manual.
Team Owner
if you want to you could also make an arrow to point in the correct direction on the crank damper.
A sharpie works well for this.
Yeah, the engine turn clock-wise when viewed from the front.
I was thinking about this yesterday. I was turning an engine by hand and it'd snap back sometimes if the turn ended on a strong compression cycle. Ya know, every engine does that when you turn it off. It spins until a compression stroke stops it and then it snaps back. Makes me think that the edict to "never turn it backwards" is overstated.
Rennlist Site Sponsor
Another way to remember is to always turn it in the tighten direction.
According to Porsche, the problem with turning it backwards is that the Belleville washers in the tensioner might be damaged.
Everytime you shut down the engine it'll shake back and forth. That's gotta be harder on the washers than turning it by hand. I'll still be going around that 1.9 extra times when I overshoot TDC.
Inventor
