PSD System Warning - Reservoir In Stock
#31
They can be re-used, at the least, once. I replaced the plastic pump inlet hose adapter and re-used the hose and clamp. You have to be careful spreading the clamp apart.
Re-closing the clamp can be done with a pair of diagonal cutters until the hose no longer slips on the fitting (tight).
BTW, these hose fittings are all static pressure.
#32
Wouldn't think these are critical connections as they draw fluid from the resv and return it. I'll probably just use left over FI clamps when I change my resv., that will give as good a seal as the OE crimp jobs.
