Large Deppression
Large Deppression
Hi
I had to push the 928 back into the garage today.
Unfortunately I pushed against the rear bodywork above the logo and it sort of buckled and has stayed buckled.
I thought this part of the car was made of plastic and would just bounce back.
Anyone know the fix for this.
Thanks.
Ben.
1984 S2 Manual.
Thanks.
Ben.
1984 S2 Manual.
Team Owner
what did you push with ?
Do the bumperetts look pushed in ?
If you pushed with another vehicle then you may have collapsed the rear shocks on the bumper.
Look under the rear cover and see if the shocks look like they may have collapsed.
You might try using the car jack against the aluminum bumper and the body next to the shock to see if it will move out dont force the shock, they are one time use.
The upper portion of the bumper doesnt usually deform unless the shocks have been damaged
The Lady's Man
Ben's car won't have bumperettes, it's a UK car.
Would hot water work rather than a heat gun? Maybe less chance of damaging paint that way. Alternatively there's a rear bumper on UK ebay at the mo.
Heat gun as pointed out by Bill, emphasis on mild heat. BTDT, works just fine. The popped out section can take days or weeks to fully "remember" its old shape, but it will. Summer sun helps, too.
Owns the Streets
Needs Camber
Needs Camber
Think OP's location is the UK.
He may be climatologically challenged.
Funniest bumper cover reshape I heard was that someone took a bumper cover with him into a hot tub . . .
The Lady's Man
